HEMI engine swap tech help
#28151
06/20/06 08:19 PM
06/20/06 08:19 PM
![](/ubbthreads/images/graemlins/bow.gif) I am looking for some tech help on swapping out my 440 in my cuda with a 426 Hemi..Can I use my existing K member and motor mounts and is there any other parts that will interchange? I can use all the Tech help I can get. Thanks Bob
Re: HEMI engine swap tech help
#28154
06/20/06 10:02 PM
06/20/06 10:02 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
I ran into no clearance between the A/C blower motor and valve cover. Had to shorten the blower motor housing and alter the air distribution box. Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Curt]
#28155
06/20/06 10:34 PM
06/20/06 10:34 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
Bob, Just make sure you stick with the chrysler block and dont be a fool and install a Indy Block set up(dont ask how I know) ![](/ubbthreads/images/graemlins/eeek.gif) Its been a nighmare. I pulled a 383 out, had it been 440 I would be kicking myself, dont let me rain on your parade, I'm just giving my opinion.
[Re: Curt]
#28156
06/20/06 10:38 PM
06/20/06 10:38 PM
Posts: 2,134 phx
metalgod
phx
depends on a lots of variables, what valve covers are you using? if your using stage 5 covers the passenger side will be right on the shock tower, you will need to massage that area for clearence, what exhaust will you be running, ttis work very good,the arruzza mounts work very well in a 440 k frame, but they are solid on one side so you will get a slight vibration not much but a little, you will need to install a milidon flexible dipstick and tube BEFORE you drop the motor in, you will also want to run the mini starter, and are you running a auto or manual trans? you will also need a 3 speed wiper motor to clear the air cleaner, also if you have power brakes your brake booster wont clear the valve covers on the hemi either, list the details of your project and we can help you better
[Re: metalgod]
#28157
06/20/06 10:53 PM
06/20/06 10:53 PM
Curt
JAX FLA
Yeah I have Stage V covers as well. Definately a pass side fenderwell problem, Maybe my blower problem was cover related as well. Curt
[Re: Curt]
#28159
06/20/06 11:06 PM
06/20/06 11:06 PM
Posts: 2,134 phx
metalgod
phx
if it is a non a/c car the blower motor will have clerance but you should remove it to install the motor, then reinstall it after motor is in, on the pass side shock tower if i had to do it again i would cut a small scooped shaped section out of the area and weld in a nice looking concave piece of metal(make it look factory) for clearance on that pass side valve cover, thats just what i would do, i would hammer it down that looks realy low class in my opinion, just make sure to install that dipstick tube before you put that motor in the chassis,dont ask me how i know. are you putting the motor in from the top or from underneath? i prefer from underneath a bit more work but well worth it, you can assemble the entire thing on the k frame, even the headers, and trans but........ i dont think those stage 5 covers will go up from underneath, they need to come off and be reinstalled after motor is in, if you go from underneath good luck, what are you doing for brakes? you should go with power disc, the correct stuff is avaialable here on this site hint hint
[Re: gomangoRTSE]
#28161
06/21/06 09:08 AM
06/21/06 09:08 AM
Mine is a 70 Cuda, I have a power brake setup for it but I might be having second thoughts about this swap..Im not to sure I want to start cutting up the engine bay to get a hemi in it. I have a lot to think about now. Thanks much for all the great help.
#28162
06/21/06 10:53 AM
06/21/06 10:53 AM
Posts: 2,134 phx
metalgod
phx
ok first off the brake booster and bracket pictured in the above attachment is the only correct assembly in apperance and function for hemi cars, in other words that is the correct one, not the only one that will work it just looks correct and functions correct and bolts to a stock location, ok, now as far as cutting up the engine compartment, it is not needed to install a hemi in those cars. the factory did it so can you without any cutting at all, my point was if you run the stage 5 heads and covers they are very tight on the pass side shock tower, and I myself, would make a slight modification, that is what I would do you dont have to do it, my current set up is basically right on the shock tower and it doesnt seem to affect the cars performance at all, i just said if i had to do it again, which i am sure i will, i would do the slight mod i spoke about, now with the a/c deal the blower motor may be larger i dont have an a/c e body so i dont know, but the a/c compressor can be low mounted and you must run an electric fuel pump with the custom hemi motors anyway, as the fuel pump pushrods and the cams dont get along, dont ask me why, just belive me its easier to install an electric fuel pump than change a motor, so with a stock v-8 k frame you can install a hemi engine with a simple motor mount kit, i like the arruzza kit myself, i have used the schumacher kit but it seemed to lift the motor slightley, others have had good sucess with the schmaucher, i just like the solid arruzza, just my choice, the shaker unit should fit no problem, agian it may need slight mods if the schmacher kit is used, other may know this better as my car car is non shaker, rememeber the factory made these cars on assembly lines, the hemi cars didnt have any differant engine bays specifications, they are the same as 318& 6 cyl cars, so if the factory did it using stock parts you can as well, the stage 5 stuff is just bigger, especially the valve covers and mods need to be made to fit them in there, shock tower, battery box etc, so it really is not a hard swap just seems that way since so few people have done them up until recently, hemis are not cheap or plentiful, even when they were new back in the day, so go for it, use the correct parts and you will ok
[Re: metalgod]
#28165
06/21/06 09:34 PM
06/21/06 09:34 PM
Sound like I have my work cut out for me..thanks for explaining this so clearly, I think I will start collecting my parts. What do you think of the year one 426 Hemi as a starting point? Thanks Bob
#28166
06/21/06 09:44 PM
06/21/06 09:44 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I learned that the "Ray Barton" valve covers are really Stage V's rebranded. What a pain. Lots of mods on my Barracuda. Use anything but those if you don't want to modify the pass inner fender.
I have a new set of wedge ear Hemi headers if anyone interested.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: gomangoRTSE]
#28169
06/22/06 04:21 PM
06/22/06 04:21 PM
Another tip: lose the power brake booster and go with manual disc brakes. I did this when converting my 70 Challenger from a 383 to a Hemi, and I like the brakes a lot better this way. They were way too touchy with the booster. Just use a master cylinder for a '72 Challenger with manual disc brakes to get the smaller piston. BTW, I designed the Hemi conversion mounting brackets that John Arruzza sells. They should set your engine in the exact same position as the factory Hemi brackets. ![](/ubbthreads/images/graemlins/Twocents.gif)
#28170
06/22/06 04:42 PM
06/22/06 04:42 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Which Stage V heads do you have? I went from a 318 to a 472 Hemi in a 70 Grand Coupe. I used the conversion mounts. The problem I had was my heads were early heads, 1978 castings. TTI had the only headers that fit those early heads with the conversion mounts. Yes and had to buy a Hemi brake booster as well. Also had to get a Hemi P/S mount to line up with the thick balancer. Also needed the small water pump pully. Used a Hemi dip stick. I added a shaker hood which you'll need to find small dia. carbs or find a base plate for the larger carbs.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
