Broken rocker #2814593
08/29/20 02:01 AM
08/29/20 02:01 AM
Midland,Tx
wyldebill Offline OP
Midland,Tx
Is there an issue with rockers breaking? I assume not, because of lack of aftermarket replacement. I picked up a supposed very low mileage 5.7 for my swap. Was starting teardown to do a cam swap. Found the exhaust rocker broken and the intake pushrod bent. Thoughts on what caused the rocker to break?
Re: Broken rocker [Re: wyldebill] #2814625
08/29/20 08:42 AM
08/29/20 08:42 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
On the same cylinder? Possibly a dropped valve seat.,look in the ports.
