Page 68 of 75 1 2 66 67 68 69 70 74 75
Re: Found 1969 4 Speed RS23L9A166042 [Re: 6bblgt] #2904865
04/01/21 09:34 AM
04/01/21 09:34 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
The engine has been rebuilt, has 0.30 pistons in it, so it is hard to tell if it came from a U code or V code car.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Found 1969 4 Speed RS23L9A166042 [Re: chargervert] #2907261
04/06/21 11:24 AM
04/06/21 11:24 AM
chargervert Offline
chargervert  Offline
I dug out an 18 spline Hemi 4 speed transmission from my transmission stash today. I am going to ask my transmission guy if he thinks he can rebuild it. I checked the VIN numbers on it,and I figured that I would post them on here to see if the car still exists. The VIN numbers are 0A230002 . If you have the car it came from, send me a pm here on Moparts, thanks Pete. My transmission guy took the transmission all apart and cleaned up the parts, he glass beaded the case, and ran taps through all the bolt holes. I found the side cover with the shift forks,and a whole other transmission in parts to make it complete. This will be available to the owner of the matching numbers car up to the point that I install it into a car. Once it is installed, it's staying in the car.
Looking for Transmission and Fender Tag for XS29L9B150466 [Re: 6bblgt] #2910716
04/15/21 08:50 PM
04/15/21 08:50 PM
blewbyu Offline
blewbyu  Offline
Would like to find orginal Hemi 4 Speed to my 69 R/T Charger, along with fender tag.
1970 Hemi Cuda 727 Transmission [Re: Alaskan_TA] #2932786
06/13/21 11:16 AM
06/13/21 11:16 AM
California
cudagee Offline
cudagee  Offline
California
I am looking for my 70 Hemi Cuda 727 transmission
Originally from British Columbia Canada
BS23R0B146394
wild71cuda@aol.com
Re: 1970 Hemi Cuda 727 Transmission [Re: cudagee] #2932795
06/13/21 11:30 AM
06/13/21 11:30 AM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If it helps at all.....
They used the number 0, not the letter O.
BS23R0B146394 as the VIN, and so if anyone has the transmission, the digits stamped on it would be 0B 146394.
(that way if anyone has it and 'googles' the partial VIN on it, this post will lead to you)
Looking for 440 block and trans [Re: Alaskan_TA] #2935290
06/21/21 12:16 PM
06/21/21 12:16 PM
FL
moparwizard Offline
moparwizard  Offline
FL
Looking for 1970 440 block and auto trans 0A155801
UPDATE BLOCK FOUND still looking for auto trans last seen in Arkansas 1980's
Re: Looking for 440 block and trans [Re: moparwizard] #2935846
06/22/21 09:45 PM
06/22/21 09:45 PM
MA
BH27G1B Offline
BH27G1B  Offline
MA
Looking for 340 block and 4 speed trans 1B337587
Looking for 440 block, 4 speed trans, and build sheet 0B190183
looking for hemi 0b221901 [Re: BH27G1B] #2941927
07/10/21 09:02 PM
07/10/21 09:02 PM
fl &TN
track pak Offline
track pak  Offline
fl &TN
Looking for 70 hemi engine 0B221901 still searching also 340 block 0R294526
Re: Wanted 9A272901 [Re: chargervert] #2941981
07/11/21 09:07 AM
07/11/21 09:07 AM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by chargervert
Originally Posted by Transman
Looking for my engine and manual trans for 9A272901.
Engine believed to be in the Northeast U.S. in a 1970 Red GTX 4 speed with AirGrabber, black interior. Lived in Tennessee and Michigan before going to the NE.
The manual trans was last known to be in a 1968 Hemi RoadRunner, Metallic Bronze when sold by the owner around 1972 to a fellow that worked at the Chrysler Chelsea Proving Grounds.
I owned a red 70 GTX 440 4 speed air grabber car,with a black interior,but it had a 66 440 engine in the car! There can't be to many of them that fit the description!
Well in talking to people, if the owner of the car knows someone is looking for the engine or trans - he is either holding out for some reason, doesn’t want to go through the hassle of removing it, or thinks it may be stolen and he will get in some trouble. I have heard all kinds of stuff as of late.
All I would like to do is reunite the engine and trans with the car more for sentimental reasons. Car is never going to be sold so I don’t care about the “added value” of it being numbers matching.
Re: Engine and Trans Lost & Found [Re: northcoastmopar] #2943296
07/15/21 01:03 AM
07/15/21 01:03 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Looking for 1969 440 block and 18 spline 4speed: 9A246400
Thank you!
209-480-5080
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Engine and Trans Lost & Found [Re: BigDaddy440] #2944104
07/16/21 09:17 PM
07/16/21 09:17 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
two 4 speeds found
8E163330
8G224308
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Engine and Trans Lost & Found [Re: davesmopars] #2949501
08/01/21 05:54 PM
08/01/21 05:54 PM
Detroit Michigan
dga26 Offline
dga26  Offline
Detroit Michigan
Looking for the 440 engine to Daytona last six 402983
Re: Engine and Trans Lost & Found [Re: dga26] #2949504
08/01/21 06:07 PM
08/01/21 06:07 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
9B 402983 is how it would appear on the original block if that helps a search engine find you?
Best of luck and welcome to Moparts.
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #2949543
08/01/21 08:12 PM
08/01/21 08:12 PM
Detroit Michigan
dga26 Offline
dga26  Offline
Detroit Michigan
Thank you
1968 18 Spline 4 speeds 8A302027,8A282306 [Re: dga26] #2950441
08/04/21 03:07 PM
08/04/21 03:07 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
These are real nice transmissions, All taken apart and cleaned First 8A282306 has a 2467 ASSY date code April 29th 1968. 300th trans built that day.
Second Transmission is 8A302027 with 2482 assy date code May 14TH 1968. 333 trans built that day.
RM27H9G182228 Found [Re: Dartman440] #2966097
09/21/21 04:18 PM
09/21/21 04:18 PM
Fargo ND
moparphilll Offline
moparphilll  Offline
Fargo ND
This was in a 69 charger from i think New Mexico Looks like out of a 1969 Roadrunner Convertible!
moparphilll@aol.com
Re: RM27H9G182280 Found [Re: moparphilll] #2966212
09/21/21 11:16 PM
09/21/21 11:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
shruggy RM27H9G182280 scope
Re: RM27H9G182280 Found [Re: 6bblgt] #2973620
10/12/21 04:30 PM
10/12/21 04:30 PM
Colorado
CuriousYella70 Offline
Colorado
Looking for original 340 and 727 from my 1971 340 Duster. To my knowledge, spent most of its life in southern Washington.
VIN: VS29H1E115200
719-339-5417
FOUND 4 speed / ebody? [Re: CuriousYella70] #2974059
10/13/21 05:50 PM
10/13/21 05:50 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Was getting some rear end work done on my pickup truck and saw this in the transmission shop. I talked to the guy and he'll sell it
IMG_20211013_105543.jpgIMG_20211013_105505.jpgIMG_20211013_105453.jpgIMG_20211013_105447.jpg
Trying to enjoy life!
Re: FOUND 4 speed / ebody? 0E 108380 [Re: calmopar] #2974065
10/13/21 06:08 PM
10/13/21 06:08 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
0E 108380 is from a 1970 Barracuda, Gran Coupe or Cuda.
New number to me, so I'll record it in the 1970 LA Registry with you as the contact person.
Thanks for reporting it!
