Who uses Victor heads on a 440? #281391
04/08/09 01:20 PM
04/08/09 01:20 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Considering different heads (got Stage 6s now) for my 440 and am wondering what sort of results people have had with them. Anybody?
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281392
04/08/09 01:49 PM
04/08/09 01:49 PM
SoCal
Brian Hafliger Offline
SoCal
Here's a detailed post I did on Gbob's engine. Based on a 440, just that it was a MP block.
Brian
https://board.moparts.org/ubbthreads/show...rue#Post5056913
Brian Hafliger
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281393
04/08/09 03:36 PM
04/08/09 03:36 PM
AndyF Offline
AndyF  Offline
They have really good flow numbers out of the box. I had a set of Victor MW heads that I sent to Dwayne for flowbench evaluation. The Victor heads do require special rocker arms and the relocated exhaust ports can be an issue.
Re: Who uses Victor heads on a 440? [Re: AndyF] #281394
04/08/09 03:52 PM
04/08/09 03:52 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
My 2" hooker super comps bolted up ok to the MW victors. They are tight to the t bar on the pass side, and contact the frame rail there as well, but that's due more to the fitment of the supercomps than the port location. They had to be "clearanced" to fit with the eddy rpm's that were on there before the victors.
Was was even able to bolt up the exhaust system, so the collector location didn't change much with the new heads, maybe a 1/4' or so.
Re: Who uses Victor heads on a 440? [Re: G_bob] #281395
04/08/09 03:55 PM
04/08/09 03:55 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
what are you going to do with the stage 6 stuff if you go to the victors? i have someone looking for some heads.
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281396
04/08/09 05:48 PM
04/08/09 05:48 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
I have a set of standard port Victors on my 440 that I have run for 2 years with good results. They are out of the first run of heads that Edelbrock did.
Re: Who uses Victor heads on a 440? [Re: dragnduster] #281397
04/09/09 11:53 AM
04/09/09 11:53 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All I can say is that I bought a set from Muscle Motors when they first came out, then got tired of there being no good choice of affordable rockers. I ended up selling them to another shop who said they wanted a set to use for developing their own CNC porting program.
Did anybody ever figure out what the intake rocker offset really needs to be for a Victor head? From what I recall when mocking up different rockers, it looked like it was going to take .650-.700".
Re: Who uses Victor heads on a 440? [Re: BradH] #281398
04/09/09 12:26 PM
04/09/09 12:26 PM
SoCal
SoCal
TD's are .650 offset. The heads need considerable clearancing with them or any rocker setup for that matter!
Brian
Brian Hafliger
Re: Who uses Victor heads on a 440? [Re: Brian Hafliger] #281399
04/09/09 12:48 PM
04/09/09 12:48 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mopar and Crane ended up going with .565 offset on P5153899 and 3900 (retail $636 for either pn).
I have a set of 3900s, and also a set of the Hughes 1.5s ($595 retail) and Hughes states they're using .600 offset.
If I ever get around to using the heads or any of the other paraphenalia I'll let you know how it works out....but as Brian states, I'd expect to check and correct the pushrod clearance in every case.
For now I haven't come close enough to seeing the potential of unported rpm heads, let alone Victors....but it's fun to look at all the pretty parts sitting on the shelf I guess
Rich H.
Esse Quam Videri
Re: Who uses Victor heads on a 440? [Re: BradH] #281400
04/09/09 01:20 PM
04/09/09 01:20 PM
AndyF Offline
AndyF  Offline
I had a set of Victor MW heads in my shop most of last year and I mocked up various rocker arm configurations on them. The MW version heads are a slightly different casting than the standard port heads and they require a little more offset. From what I could tell, a .650 offset intake would work on a RB motor with a 3/8 pushrod but it was tight. An offset intake lifter helped the situation.
I mocked up a Jesel rocker arm and the Jesel setup wanted more offset, something in the range of .700 or even .750 looked good. I didn't think the HS rocker arms were all that great of a fit on the Victor heads. The T&D setup looks really nice in pictures but I never had a set in my hands. If I was building a motor with Victor heads I'd probably go with the T&D or maybe I'd check out what Hughes has.
In the end I decided not to build up that set of heads since I had other projects in the works so I sold them.
Re: Who uses Victor heads on a 440? [Re: AndyF] #281401
04/09/09 01:26 PM
04/09/09 01:26 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Would Indy 440-1 rockers work on the victor heads?
Re: Who uses Victor heads on a 440? [Re: Harley] #281402
04/09/09 01:33 PM
04/09/09 01:33 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i used the hughes intake rockers on my shafts with my old exhaust rockers and have not had any problems.a little pushrod clearanceing was needed done by fbs63
this was on a low deck with 1.6 rockers and 3/8 push rods
WAXER
Re: Who uses Victor heads on a 440? [Re: Harley] #281403
04/09/09 03:39 PM
04/09/09 03:39 PM
AndyF Offline
AndyF  Offline
Maybe the offset would be correct but I think the standard Mopar rocker arms are actually a little too long for the Victor head. The Victor head is taller than a production head so the pushrods and valves are both longer. Since those two items are at an angle to each other as they get longer the distance between them gets shorter.
Re: Who uses Victor heads on a 440? [Re: AndyF] #281404
04/09/09 04:37 PM
04/09/09 04:37 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Thanks for the info Andy, I thought that the 440-1 and the victors would be the same height.
Re: Who uses Victor heads on a 440? [Re: Brian Hafliger] #281405
04/09/09 07:01 PM
04/09/09 07:01 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Brian
I did some searching on old posts and found some other good Victor stuff you posted, too. Thanks.
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281406
04/09/09 08:28 PM
04/09/09 08:28 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
I just checked mine .750 intake offset mine are TD 1.5 rockers.
Re: Who uses Victor heads on a 440? [Re: hot67cuda] #281407
04/09/09 09:53 PM
04/09/09 09:53 PM
Ames, Iowa
LoneMopar Offline
LoneMopar  Offline
Ames, Iowa
I am going to try some Victors this year.
I'll post some results in a couple weeks.
Here's a pic with Hughes rockers .600 offset.
The heads needed a fair amount of pushrod clearancing.
.750 offset rockers would really make a lot of pushrod angle.
My next set of roller lifters will be offset!
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281408
04/09/09 10:06 PM
04/09/09 10:06 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have a pair of victors and t&d .550 offset and offset roller lifters
the fit is great, after alot of grinding.
after porting the intake flow was 348cfm at .650 lift
Re: Who uses Victor heads on a 440? [Re: PorkyPig] #281409
04/10/09 07:29 AM
04/10/09 07:29 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: Who uses Victor heads on a 440? [Re: QWK_ENUF] #281410
04/10/09 10:10 AM
04/10/09 10:10 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
How much higher would a 440 need to rev, to get the most out of the victors, compared to a larger engine.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
