Hemi dip stick #2812070
08/22/20 08:47 PM
08/22/20 08:47 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Anyone got a picture of a Hemi dip stick instaled? I have a factory straight one with bolt attachment tang on it and I need to see how it’s bent, with dimensions. Where does the tang attach? With a 440 it goes on the motor mount but of course the Hemi has none. It’s about 26” long now. Thanks
Re: Hemi dip stick [Re: cudaman1969] #2812101
08/22/20 09:55 PM
08/22/20 09:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Manifolds or headers?
Re: Hemi dip stick [Re: NITROUSN] #2812129
08/23/20 12:34 AM
08/23/20 12:34 AM
fredericksburg,va
fredericksburg,va
I’ll use headers unless I find a set of manifolds some day. Was it bolted to the manifold?
Re: Hemi dip stick [Re: cudaman1969] #2812133
08/23/20 01:17 AM
08/23/20 01:17 AM
North Carolina
469runner Online content
469runner  Online Content
North Carolina
I had a little clamp that came with the dipstick assembly. Bolted it to the exhaust flange. Look closely.
Re: Hemi dip stick [Re: 469runner] #2812149
08/23/20 07:24 AM
08/23/20 07:24 AM
VA
dragon slayer Offline
VA
As far as dipstick, which pan you going to use? 66-67; 68-69; 70-71? The reproductions run around $70-90.
Attached PDF document
68 Hemi Dip Stick.pdf (41 downloads)
Re: Hemi dip stick [Re: dragon slayer] #2812184
08/23/20 10:14 AM
08/23/20 10:14 AM
fredericksburg,va
fredericksburg,va
Wow, the bulletin with those measurements and the engine pic are helpful. I must have a later pickup tube because it makes the pan sit about an inch off the block. Will a later pan fit in a 66 k-frame?
Re: Hemi dip stick [Re: cudaman1969] #2812197
08/23/20 10:45 AM
08/23/20 10:45 AM
VA
VA
I think it should. The 70-71 pan which is more common and reproduced at a cheaper price point, is shallower but longer in length so it does sit close to the k frame. The 68-69 was deeper and sits below k frame level but shorter in length so more space to K frame. Plenty of pictures on the differences on the web.
Re: Hemi dip stick [Re: dragon slayer] #2812212
08/23/20 11:33 AM
08/23/20 11:33 AM
N
NITROUSN Offline
NITROUSN  Offline
N
TTI Has a document showing how to bend the factory tube to clear the headers.
Re: Hemi dip stick [Re: 469runner] #2813413
08/26/20 07:30 AM
08/26/20 07:30 AM
robertop Offline
robertop  Offline
That is a wrong position. In my original 69 bird the clip and the tube are attached to the first bolt, corresponding to the no. 1 plug, to make it clear.
Re: Hemi dip stick [Re: cudaman1969] #2813551
08/26/20 01:21 PM
08/26/20 01:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mine is just a generic Taiwan Chrome one that I modified to work, and later sanded and painted.
(bent, cut the tab of, welded the tab where I wanted it. I'm obviously not trying to make it look stock).
It was advertised for 440, but being straight it clearly would not have fit that application either,
without (at least) some serious bending.
This part seems to be a pain for alot of folks.
Rich H.
Esse Quam Videri
