Re: cleaning fuse panel / terminals / wire harness [Re: 4406bbl] #2812243
08/23/20 01:23 PM
08/23/20 01:23 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Backside, then use a new terminal to test that the females are tight. Only remove what is loose and squeeze them.
Re: cleaning fuse panel / terminals / wire harness [Re: 4406bbl] #2812252
08/23/20 01:54 PM
08/23/20 01:54 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Even the red and black are tight on this one.
Re: cleaning fuse panel / terminals / wire harness [Re: GoodysGotaCuda] #2812283
08/23/20 04:24 PM
08/23/20 04:24 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted by GoodysGotaCuda
Originally Posted by dart4forte
Originally Posted by kingdragon
Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best.
-KD
Evaporust
I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust.
Wonder if I can do that with the female/fixed side of my bulkhead connector? work
More of a spray it on and wash it off type situation.
Yes, I did that also. I had a 65 Chrysler300 from San Francisco. Has a lot of corrosion. I pulled the bulkhead portion and soaked it in a plastic pail. Did the same to the connectors. Both soaked overnight. Took the out, used a spray bottle of water to rinse and blew them out with compressed air. They looked new. Poured the contents of the Evaporust bankin the container to re-use later.of course I disconnected the battery.
Abe Lincoln
Re: cleaning fuse panel / terminals / wire harness [Re: larrymopar360] #2812354
08/23/20 07:56 PM
08/23/20 07:56 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
evaporust and a dremel with a wire brush head
