Re: E-Body Cowl area
[Re: Gunsling3r]
#2810895
08/19/20 10:48 PM
08/19/20 10:48 PM
Posts: 1,752 Phila
PhillyRag
Phila
I was wondering how you guys dealed with surface rust in the cowl area, I have no holes thankfully due to the car being inside for the past 25 years, but, some pretty good surface scale, engine bay has already been painted so, I was wondering how to best deal with it . If you mean the inside area where wiper linkage is: best to have delt with it before bay was painted. Otherwise run risk of making mess of bay when trying to work inside there.
[Re: Gunsling3r]
#2811719
08/21/20 06:25 PM
08/21/20 06:25 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
Well going thru this cause my son cuda is being done. Did before painting. So is the car apart or together ? you could still take care of it IMO . Not sure all bad it is, you could scotch brite, sand whatever. Wipe down, clean /prep for paint. Tape off good, spray, need a very small gun or air brush to get into spots. Not that you see it, so you could brush some of the spots that you can see.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: Gunsling3r]
#2811818
08/22/20 12:16 AM
08/22/20 12:16 AM
Posts: 1,752 Phila
PhillyRag
Phila
Car is together, have to keep it somewhat mobile where i live. I was thinking of using a Dremel with a small wire wheel and my hand, use some vinegar on rags to get the harder spots, then some por 15 or the like. No holes just some surface scale. Still have not figured how to get those cursed wiper arms off and i have the Service manual!! Power washers if wand end is small enough. Also have used assorted siphon type sprayers to clean out those nasty corners. Some of those longer engine cleaning brushes that are flexible. Most mess will drain away at end openings. Not a fun area to clean for sure.
[Re: Little Detroit]
#2812136
08/23/20 02:24 AM
08/23/20 02:24 AM
Posts: 1,752 Phila
PhillyRag
Phila
mask off your cowl to firewall seam really well,POR-15 is thin and runs really easy, do not want it to run threw you seam and all over your pain. Would be a good indicator of "open" seams. Would also "seal" any tiny openings. If you do the por-15 thing: apply it 1st to any corner areas inside that have seams or overlapping metal. Nice to have any type of squirt bottle with a long nozzle on it. Do the flat areas last.
