Re: Cooling issues help? [Re: Sniper] #2812081
08/22/20 09:02 PM
08/22/20 09:02 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Speaking of airflow, I think the Contour fans are presenting a little restriction (when they are off) that is more important at low speeds.
I'm thinking of rigging another relay to run them at low speed all the time, and still have the temp switch turn them on full. Either use the nichrome resistor that the fans come with, or a big 1 ohm resistor (both of which I have). That'll also cut down on the sudden load thrown on the alternator when they kick on, which makes idling interesting (non-existent low speed torque with 272@.050).
thoughts? work
Re: Cooling issues help? [Re: DrCharles] #2812168
08/23/20 09:12 AM
08/23/20 09:12 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You could use a motor controller to basically give you infinitely variable speed based on coolant temps.
This will minimize any sudden hit to the charging system and give you the cooling you need rather than the cooling you get.
https://derale.com/product-footer/e.../pwm-fan-controller-push-in-probe-detail
Re: Cooling issues help? [Re: Sniper] #2812188
08/23/20 10:31 AM
08/23/20 10:31 AM
West Plains, MO
West Plains, MO
Yes, of course I could but that requires spending money, to which I am allergic whistling
Also there are mixed reviews on many of the common PWM controllers (reliability problems). Someday I'll build my own, it's not that complicated to design, but I'm feeling lazy at the moment wink
So for now, is there any point in keeping the fans turning on low speed? I could just hook up the resistor with jumpers and see if it makes any difference.
Re: Cooling issues help? [Re: DrCharles] #2812196
08/23/20 10:44 AM
08/23/20 10:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Wouldn't hurt to see if it does anything useful. If it does you can put in a more permanent solution, if not nothing really lost, just be sure the resistor can handle the heat.
Re: Cooling issues help? [Re: DrCharles] #2812203
08/23/20 11:08 AM
08/23/20 11:08 AM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
I'd say nothing wrong, sounds like system works perfect, first of boil point is 212, increase 3 degrees per pound of cap, so 16 lb cap, boil point is about 260, all cars with factory electric fans operate in the 240 on and off at 205 range, fuel atomizes best around 210, if your staying below the 200 mark your system is perfect, Licensed tech for 38 years, I wish people would understand this more. Stat is to help in heating engine up to the temp range you wish to be the coolest temp for it to run at and control the speed of the flow in the system, it has little to do with highest temp reached, 90 % of the time if overheat is experienced there is generally another issue. I lick to see all my cars and customers cars run around or just below the 200 - 210 range. as for the fan cycle on and off, that is what they do, if it cycles to much, you have room to increase your on setting a little, let it get just a little hotter before it comes on.
Re: Cooling issues help? [Re: DrCharles] #2812207
08/23/20 11:18 AM
08/23/20 11:18 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If you temporarily hook up a DC ampmeter to the fan wires you can monitor whether the blades are blocking airflow.
If the amps significantly drop as you drive at higher and higher speeds the blades are blocking airflow.
Re: Cooling issues help? [Re: 360view] #2812233
08/23/20 12:39 PM
08/23/20 12:39 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Except, as I understand it, the fans are just freewheeling so there should be no current drop to see.
Re: Cooling issues help? [Re: 360view] #2812234
08/23/20 12:40 PM
08/23/20 12:40 PM
West Plains, MO
West Plains, MO
Thanks for the suggestion... but wouldn't the amps drop anyway (because the fan is having to do less work at speed, with the ram air coming in)? work
Re: Cooling issues help? [Re: DrCharles] #2813124
08/25/20 03:47 PM
08/25/20 03:47 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
trying to fix a problem that doesnt exist
5549 post on old board
Re: Cooling issues help? [Re: 05dakota] #2813131
08/25/20 04:16 PM
08/25/20 04:16 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep.
Re: Cooling issues help? [Re: Pacnorthcuda] #2813173
08/25/20 05:40 PM
08/25/20 05:40 PM
West Plains, MO
West Plains, MO
Yep.
Thanks, I feel better now. rolleyes
I want my engine to run just above the thermostat temp while cruising on the highway. Right now it doesn't so something isn't doing its job.
Yes, I know 198 is not overheating so I really don't have to fix it. As long as it doesn't get higher than that while idling in traffic it's passable but not ideal.
Anyhow I got the Milodon high-flow 180 degree 'stat this afternoon but it's too hot to run around draining and refilling coolant today!
Re: Cooling issues help? [Re: DrCharles] #2813357
08/25/20 11:41 PM
08/25/20 11:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had several Auto Meter expensive race mechanical gauges read way hotter than the engine coolant was, one would read 140F when it the coolant flowing out of the upper radiator hose into the radiator was below 95F puke
I found that one by sticking my finger in the swirling coolant scope
Re: Cooling issues help? [Re: Cab_Burge] #2813575
08/26/20 02:45 PM
08/26/20 02:45 PM
West Plains, MO
West Plains, MO
Quote
Good point Cab, I can't recall if I checked the mechanical gauge against a pot of boiling water or a mercury lab thermometer.
But the old and the new stat opens right about the temp it's supposed to(183-184F), so I can tell it's pretty close.
I put in the Milodon high-flow thermostat today. It looks just like the 'stat that was in there (and the old one has a Pentastar logo on it, too). Didn't make any difference frown
So the next move would be a new aluminum radiator since rodding or recoring the copper/brass one would likely be more expensive than buying a modern one.
Or I can just live with the slightly-higher-than-I-like highway temps, as previously pointed out wink
