Any of you guys have any suggestions on cleaning the terminals and fuse block on my dash harnesses? I was thinking about soaking the fuse block in a bowl of vinegar. My other idea is maybe evaporust. I want to put my harness terminals to look as nice as the flawlessly restored dash assembly. Looking forward to the responses. Working knowledge is best.
-KD
Evaporust
I soaked my bulkhead connector in it for 24 hours, rinsed with water and hit it with air. Came out squeaky clean. Removed corrosion, dirt and rust.
