Re: Jerico GTX VS Hemi Joel dragstrip dinner bet
[Re: Cab_Burge]
#2923685
05/17/21 09:10 PM
05/17/21 09:10 PM
Posts: 10,029 MN
JERICOGTX
MN
I love those early bodies and early hemiroid motors Joel has it right for the perfect street rod, other than them suicide doors The Coupe doesn’t have suicide doors. Secret weapon? I’m not scared. I’m hoping the new clutch program picks the car up at least a tenth.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2923692
05/17/21 09:44 PM
05/17/21 09:44 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Hope is not a strategy. Maybe you could throw some coins in the wishing well too. (:
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2923699
05/17/21 10:10 PM
05/17/21 10:10 PM
Posts: 10,029 MN
JERICOGTX
MN
Hope is not a strategy. Maybe you could throw some coins in the wishing well too. (: At the very least, my first pass of the year will secure yet another dinner out of you. Going faster yet will be icing on the cake.
69 GTX
68 Road Runner
[Re: Jeremiah]
#2923725
05/17/21 11:31 PM
05/17/21 11:31 PM
Hemi_Joel
Minnesota
Jeff can start licking his chops, I had another setback tonight.
[Re: Hemi_Joel]
#2923759
05/18/21 04:55 AM
05/18/21 04:55 AM
Posts: 10,029 MN
JERICOGTX
MN
Jeff can start licking his chops, I had another setback tonight. Oh ohhhh... text me.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2924002
05/18/21 03:05 PM
05/18/21 03:05 PM
Hemi_Joel
Minnesota
At the very end of the night last night, I stepped on the clutch pedal, and the hydraulic throwout bearing popped open and fluid ran out the bellhousing. Not too hard to fix, but just more time. And I'm teetering on the precipice of not having enuff time to beat Jeff out of a dinner, and be ready for the Midwest Drags. I got out there early before work today and pulled the trans so assess the damage. One of the orings was torn and hanging out. Hopefully a new O-ring and reassembly will cure it. I also need to figure out how to keep it from happening again.
[Re: Hemi_Joel]
#2924012
05/18/21 03:19 PM
05/18/21 03:19 PM
Posts: 10,029 MN
JERICOGTX
MN
As we have discussed, as time goes on, we'll have many dinners together. It's just a matter of who will have to pay the tab. I'm at a stand still. You have time, and don't worry about it.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2924015
05/18/21 03:27 PM
05/18/21 03:27 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I really detest aftermarket t/out bearings. Have yet to see one that did not have some strange issue eventually.
What bellhousing is in that thing Joel? Hopefully it will be a quick r&r for you. I'd grab a couple of spare o-rings for the tool box too.
[Re: Jeremiah]
#2924018
05/18/21 03:30 PM
05/18/21 03:30 PM
Hemi_Joel
Minnesota
Jerimiah, its a QUicktime bell. The TO bearing worked fine with the long style Mcleod Soft Lok. But now I put in a diaphram style Mclead RTX. I went thru the measure/calculate thing to determine the # of rings behind it. I'll have to double check that. Or could the diaphragm be too soft or have more travel of the fingers?
[Re: Hemi_Joel]
#2924059
05/18/21 05:33 PM
05/18/21 05:33 PM
Jeremiah
Rogue River, OR
In my experience the finger height on the long style plate is way taller than a diaphragm style. How much difference was it between the two?
[Re: Jeremiah]
#2924071
05/18/21 06:19 PM
05/18/21 06:19 PM
Hemi_Joel
Minnesota
Jeremiah they were about the same height, but the long clutch was a single desk, the diaphragm is a dual disk. When I get home from work I'm going to double check the measurements.
I've left two messages for American powertrain, that's who made the throw out bearing. They haven't called me back yet. I had so much trouble with them when I originally bought the stuff, I would never buy anything from them again.
[Re: Hemi_Joel]
#2925721
05/23/21 12:58 AM
05/23/21 12:58 AM
Hemi_Joel
Minnesota
Jeff is getting nervous that he might have to skip a house payment after I order shrimp and lobster, with a filet mignon on the side. Finally got the Hemi Coupe mostly back together, Sunday I fire it up. My shop looks like a tornado went thru...
[Re: Hemi_Joel]
#2925742
05/23/21 08:17 AM
05/23/21 08:17 AM
Jeremiah
Rogue River, OR
After all of that no verdict on the technical stuff? : D
Glad you have it back together and ready to run. I'd imagine that thing is pretty tight to work on with the monster tko?
[Re: J_BODY]
#2926034
05/24/21 03:43 AM
05/24/21 03:43 AM
Posts: 10,029 MN
JERICOGTX
MN
While Joel still has the dreaded 5% left to finish his Coupe, the Road Runner is ready to go.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2926219
05/24/21 03:51 PM
05/24/21 03:51 PM
Hemi_Joel
Minnesota
Yes, the dreaded 5% has reared its ugly head. I made up just the right length spacer to go between the TO bearing and the Transmission, put it together, got it running. But the clutch won't disengage cleanly enuff to put it in gear. So the trans needs to come back out and get that figured out. Also I messes up the threads for the fuel inlet in one of the carbs, it leaks a little so I need to fix that. But the motor seams to have no issues.
[Re: fast68plymouth]
#2926279
05/24/21 08:26 PM
05/24/21 08:26 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I don’t really care who wins........ but I am enjoying some of the art work in this thread. X 2 Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2926486
05/25/21 01:48 PM
05/25/21 01:48 PM
Posts: 10,029 MN
JERICOGTX
MN
Joel and I had a discussion on the phone today, and we might have a solution to the clutch issue. If it works, we will fill everyone in on the fix. It could very well cost me a dinner, but at the end of the day, Joel is a good friend, and I want to see his car succeed.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2926505
05/25/21 02:44 PM
05/25/21 02:44 PM
Posts: 25,941 United Socialist States of Ame...
tboomer
Joel and I had a discussion on the phone today, and we might have a solution to the clutch issue. If it works, we will fill everyone in on the fix. It could very well cost me a dinner, but at the end of the day, Joel is a good friend, and I want to see his car succeed. Way to go Jeff!
