Converting face plated a833 from b body to a body
#2809079
08/15/20 12:36 AM
08/15/20 12:36 AM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
I am planning on stabbing my faceplated aluminum 18 splne 4 speed in the 68 GTS and need to convert it over to an a body case. I know i need a tail shaft housing and a mainshaft to start with. Is there anything else i am forgetting? Also, does the 23 spline trans use the same main shaft as an 18 spline. My faded memory sats no lol.
I should have bought the one for sale a few months ago and am kicking myself. Hate to pull apart a fresh trans but it needs to happen.
Thanks for any advice.
Re: Converting face plated a833 from b body to a body
[Re: Jeremiah]
#2809087
08/15/20 01:21 AM
08/15/20 01:21 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
[Re: 4406bbl]
#2809089
08/15/20 01:56 AM
08/15/20 01:56 AM
Posts: 7,475 Minnesota
Hemi_Joel
Minnesota
You are correct, the main shaft and the tail housing are the only difference. I agree with 440, the 23 spline and 18 spine transmissions use the same mainshafts. Now about that switching over from a classy B body to a lowly A body issue....
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2809118
08/15/20 05:10 AM
08/15/20 05:10 AM
Jeremiah
Rogue River, OR
Thanks guys! That is great news.
I have all of this stuff left over from my red 66 Charger that we converted to a G Force gf5r 5-speed. My other 66 charger has a Lenco 4 speed so we are good on the three pedal b bodies. : D This 68 GTS is just my winter beater and I thought it would be wise to remove the original engine before something happened to it.. I have a 500hp 451 that shiuld make 350rwhp through the manifolds and full resto exhaust system. It should dip into the 12's on street radials.
[Re: dvw]
#2809168
08/15/20 10:56 AM
08/15/20 10:56 AM
Posts: 43,096 Bend,OR USA
Cab_Burge
All the A body 4 speed cars came with the A body 4 speed for reasons not reveal to us lowly buyers and owners The driveshafts are longer also for the 4 speed cars. Jeramiah, don't count on small radials hooking well on a nose heavy 4 speed car, me thinks a good set of bias ply street and strip tires will be better on hooking, especially at the track and on airports
[Re: dvw]
#2809203
08/15/20 12:25 PM
08/15/20 12:25 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
If a 727 fits an A body why won't the 833? Granted shifter location may be different but it cant be that much different that a shift handle couldn't make up the difference. Am I missing something? Doug IIRC, it can be done, but it takes some hacking around on the crossmember area because that is where the shifter ends up.
