Factory 15" Trim Rings don't fit Factory Wheets? #2808756
08/14/20 09:18 AM
08/14/20 09:18 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I have a set of NOS 15x7 Trim Rings, the ones that were reproduced by chrysler in 2006. I also have a set of factory 1970 390 wheels that I trying to install rings on. When installing, I cant get them to seat all the way. I don't want to beat on them and possibly dent ring. Does anyone else have this problem? I tried various combinations of wheels and rings and they don't want to seat.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: RSI700VIPER] #2808762
08/14/20 09:41 AM
08/14/20 09:41 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I think that was one of the complaints of those rings, they don't fit 100%. I have a set too, and at least one of them I can't get to fully seat on a factory '450 wheel.
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: RSI700VIPER] #2808811
08/14/20 11:16 AM
08/14/20 11:16 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
That's why I spent an arm and a leg to get a set of 5 "original" 15 trim rings and then paid to have them restored for my 70 Hemi cuda vert. No repops or later Mopar trim rings fit and look correct.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: MOPARMIKE69] #2808821
08/14/20 11:37 AM
08/14/20 11:37 AM
NW New Jersey
NW New Jersey
I probably have a dozen or so 15 x 7 originals but none are perfect. Who did you use to have your rings restored?
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: RSI700VIPER] #2809437
08/16/20 11:04 AM
08/16/20 11:04 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I live in the Nashville, TN area. I use S&H Chrome Plating & Powder coating. 817 Madison Industrial Dr., Madison,TN 37115. phone 615-865-0100 They do all my plating and stainless and I have used them for years.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: MOPARMIKE69] #2809597
08/16/20 09:20 PM
08/16/20 09:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The trim ring has this step that hits the rim edge and stops it from going on. So hitting more will just damage the ring
Measure this distance on an original and compare to your Reproduction rings. mopar performance part numbers start with The letter P.
NOS Chrysler part numbers do not.
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: NANKET] #2809625
08/16/20 11:27 PM
08/16/20 11:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
scope VS. an original 15x7.0" trim ring
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: MOPARMIKE69] #2810723
08/19/20 03:19 PM
08/19/20 03:19 PM
NW New Jersey
NW New Jersey
Thanks Mike. I'll look them up.
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: NANKET] #2810726
08/19/20 03:23 PM
08/19/20 03:23 PM
NW New Jersey
NW New Jersey
NANKET - Are you sure that the problem? I think I'm well past that on the step in the rim. Is there a simple Mod to get them to seat? Maybe cut a relief slot?
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: RSI700VIPER] #2810742
08/19/20 04:27 PM
08/19/20 04:27 PM
A727Tflite Offline
A727Tflite  Offline
Take some modeling clay and make some strings of it, place on the wheel from bead area down towards the web. Install the trim ring and remove it, see where the clay gets cut.
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: A727Tflite] #2810755
08/19/20 05:08 PM
08/19/20 05:08 PM
NW New Jersey
NW New Jersey
It appears that the inner ring overlap is the culprit. If you look at my OP, you can see that only this area is hanging. Maybe I can dremel the overlay.
Re: Factory 15" Trim Rings don't fit Factory Wheets? [Re: A727Tflite] #2810756
08/19/20 05:09 PM
08/19/20 05:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I remember when this issue was being discussed. I thought the problem was determined to be that the ring with the "teeth" on it isn't positioned correctly when welded. You can see in one of the pictures that the end of the ring is offset.
