I've used several different Bullet and Ultra Dyne solid roller grinds in my motors, my current 518 C.I. 400 block stroker motor on E85 has ran a best of 8.86 at 150.+ MPH in the 1/4 mile at Woodburn last summer at the Mopar race their. It has ran 5.77 in the 1/8 mile at 120 MPH in Medford OR. several weeks ago.
That cam is a Ultra Dyne 312/312-08R grind with 282 degrees on both lobes at .050 with .4567 lobe lift ground on a 108 LSA installed at 106 ILC. It has a set of ported 440-1 heads with a set of Jesel 1.55 ratio paired shaft rocker arms and a Indy 400-3 intake with a Holley Dominator carb switch over to E 85 by A.J. at Bob George racing
It has between 14.56 to 1 and 15.0 to 1 compression ratio due to the combustion chamber sizes varying
ITHS
I currently shift it at 7300 RPM, soon to try 7500 RPM
I found my notes on setting the cam timing, ILC, at the valves and P to V clearances, I installed it 104.5 ATDC on the intake lobes which put the exhaust lobes at 114 degrees BTDC. It has .678 net lift at the valves with checking springs with the lash set at .020 cold, room temps in the mid 70F.
It has .100 + V to P on both valves
You can do the math on what it calculates at max lift with zero lash and go from their on selecting your cam
