Diesel guys...So I found the exhaust brake button.........
#2807420
08/10/20 07:48 PM
08/10/20 07:48 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Finally getting around to figuring out all the buttons on the new to me 2016 Ram 2500 diesel.
Found the exhaust brake button (I thought it was an option my truck didn't have)
Tested it out and it seems to work great although my wife doesn't like the way it works/feels/sounds.
So in doing some research it appears many diesel owners use the exhaust brake all the time, towing or not.
The claim is it keeps the turbo cleaned out and keeps brake wear down.
So for the experts how often do you use the exhaust brake? Auto or full on? Tow/haul mode engaged or not?
Thanks.
Re: Diesel guys...So I found the exhaust brake button.........
[Re: KillerBee]
#2807441
08/10/20 08:31 PM
08/10/20 08:31 PM
Posts: 614 Id
mopeman
Id
On my trucks with the brake, I left it on all time except in slippery conditions.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
[Re: RapidusMaximus]
#2807563
08/11/20 07:32 AM
08/11/20 07:32 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I don't know for sure but I imagine the parts involved in the exhaust brake are being exercised anyways as part of the variable vane function fo the turbo. I don't think they are blade that shuts off the exhaust like the older aftermarket units did. But like anything else lack of use is hard on stuff so its a good idea to use it on occasion either way I imagine.
I have a 2016 Duramax 3500 as a company pickup and I use the exhaust brake on it semi regularly just to use it. It is pretty livable driving empty with it on, its not near as aggressive as the 2016 Ram I test drove.
68 Barracuda Formula S 340
[Re: hemi70se]
#2807620
08/11/20 11:14 AM
08/11/20 11:14 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
I have a 2010 that started throwing codes (I think it was a P0046 TURBOCHARGER BOOST CONTROL CIRCUIT PERFORMANCE). I read on the web that using the engine brake exercises the vane actuator ring and helps keep the ring freed up. I started using the engine brake and the code cleared and hasn't come back. Since then I try to use the brake as much as I can on hills.
[Re: J_BODY]
#2809972
08/17/20 10:35 PM
08/17/20 10:35 PM
Posts: 2,497 God's Country Maryland
GODSCOUNTRY340
My 2011 only seems to work when I use it along with the tow haul button. Is this normal?
