Front end assembly #2806878
08/09/20 02:15 PM
08/09/20 02:15 PM
central ohio
mopar rookie Offline OP
central ohio
I have my front end just finger tight assembled. Should I go ahead and torque everything down now or wait till it’s installed in the car? Is there any sequence that needs to be considered? Anything I need to lubricate at all. Thanks
Re: Front end assembly [Re: mopar rookie] #2806881
08/09/20 02:23 PM
08/09/20 02:23 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
leave loose til you have everything in (including engine/transmission, etc) . . . otherwise you will have things "loaded up" in wrong position . . .
Re: Front end assembly [Re: a12rag] #2806952
08/09/20 04:50 PM
08/09/20 04:50 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I'll second that ,but you might want to use the factory style paint dabs as you torque and cotter pin each connection so you don't miss any. It would suck to lose a critical front end connection at speed.
Re: Front end assembly [Re: 67_Satellite] #2806968
08/09/20 05:32 PM
08/09/20 05:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Some things, it doesn't matter. For example, the pitman arm to to the steering box shaft. Tierods and ball joints fall into this category, the part that moves here is not the part you are torquing.
Some things, it does matter, such as bushings that twist, like control arms.
Re: Front end assembly [Re: mopar rookie] #2806976
08/09/20 05:48 PM
08/09/20 05:48 PM
AndyF Offline
AndyF  Offline
Always a good idea to read the FSM and follow the instructions.
