What Type of Plating on Radio Case/Shell #2806704
08/08/20 09:21 PM
08/08/20 09:21 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I am looking at clean/re-plating the case/ housing on my 1972 AM radio.What type of plating was original used? I read one place that said cadium,but after cleaning up a spot on the case,it almost looks like tin plating.Like on filler tubes.Thanks for any advised
Re: What Type of Plating on Radio Case/Shell [Re: 44D6PAKCUDA] #2806731
08/09/20 01:28 AM
08/09/20 01:28 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Radio cases were and still are made from Galvanneal, which is cold rolled steel sheet that has been hot dipped in zinc, blown off with 'air knives' for zinc thickness control, followed by annealing, "causing iron and zinc layers to diffuse into one another causing the formation of zinc-iron alloy layers at the surface. The annealing step is performed with the strip still hot after the galvanizing step, with the zinc still liquid. The galvanising bath contains slightly over 0.1% aluminium, added to form a layer bonding between the iron and coated zinc." (From Wikipedia.)
Since Galvanneal is a specialized steel mill product, there is no way to do a restoration re-plate in an identical way. The surface can be renewed somewhat by wiping or scrubbing with a Scotch-Brite pad and vinegar followed by waxing.
A vintage radio case could certainly be zinc plated, but it probably won't look quite the same as Galvanneal. Besides, there were stickers and stamps on the original cases.
Re: What Type of Plating on Radio Case/Shell [Re: kentj340] #2806763
08/09/20 08:57 AM
08/09/20 08:57 AM
Thanks for the reply and the great info !!
