I just got a new starter for a 99 dakota for my big block charger , the starter has a black plug on the small or what would be the small stud is the stud under there ? can i cut the plastic off is the stund under it ,, the pin connector is tiny thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
