Which Generator for Enclosed ?
#2806056
08/07/20 09:10 AM
08/07/20 09:10 AM
Posts: 4,676 On the parachute mount
n20mstr
I currently have a Harbor Frieght generator, 3200 watt. Its 10-11 years old now and honestly it cant keep up with my trailer. I cant run too many things at once. It has AC/Heat , microwave, inside lights, outside lights, and I run Water bath bottle heater, battery charger, and fans to cool the engine between rounds. Harbor freight has 4375, and 6500 watt. What size do I need to run some of this stuff together at one time ?
My current one still runs great, starts on the first pull, but it cant keep up...LOL
and yea, im sure everyone around me wants to kill me because its loud...LMAO
....BAD A$$ STREET CAR.....
Re: Which Generator for Enclosed ?
[Re: n20mstr]
#2806061
08/07/20 09:27 AM
08/07/20 09:27 AM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Harbor freight ones are extremely over rated on sizes .. Sometime, when you have everything running, put a load meter on, you will be shocked ( no pun intended) on how low of volts you are actually running on and when you do that, it hurts all the electrical components . I bought a Honda 6500 inverter years ago for $3800 new with a good sam discount, still works great
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: justinp61]
#2806072
08/07/20 10:01 AM
08/07/20 10:01 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
A couple years ago I was at a race In Harrisburg IL and the guy parked next to me had a big enclosed trailer. The generator, a big Honda, was on a slide out on my side of his trailer. It was quiet enough my nephew and I could carry on a conversation without having to raise our voices with it running about eight feet away. HONDA
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: bigdad]
#2806074
08/07/20 10:03 AM
08/07/20 10:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I bought a used Onan 4500 gen works great.. I did have to replace a coil once but thats been it.. Onan gens were made for motor home and such.. its a low rpm engine and its nice and quiet.. it will control all the load I have in my trailer.. I have AC also and a compressor and lights(over all trailer length is 43')
[Re: MR_P_BODY]
#2806083
08/07/20 10:21 AM
08/07/20 10:21 AM
Posts: 826 Georgia
66coronet
Georgia
We have a Honda and a Champion. I would buy the Champion again in a heartbeat. Just as good as the Honda and much less. We had a Motorhome generator malfunction at Bowling Green. We used the Champion to run the Motorhome. It ran 2 ac units, the fridge, hotwater heater and on plus the trailer lights and battery charger.I was impressed. This is what we have. Thats cheap for a good and quiet inverter generator. https://www.cabelas.com/shop/en/champion-power-equipment-3500w-remote-start-inverter
[Re: 66coronet]
#2806096
08/07/20 11:06 AM
08/07/20 11:06 AM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I too have a inverter Champion generator. I bought it after my buddy with a 3000 watt Honda wouldn’t start his motorhome generator but his Dads Champion would. On weekends I don’t take my motorhome I use my 2000 watt Honda. I haven’t used my Onan in probably three years but they are great generators.
[Re: 340Cuda]
#2806113
08/07/20 11:42 AM
08/07/20 11:42 AM
n20mstr
THANKS \ BUT im not looking for a $3,000.00+ generator, im broke...lol
Just asking what watt I need to run my trailer as the 3000 watt I have now doesn't cut it.
Im about to get a 6500 Top FUel generator, nice and loud and run everything...LOL
[Re: n20mstr]
#2806132
08/07/20 12:24 PM
08/07/20 12:24 PM
MR_P_BODY
Sounds like you already knew what you were gonna get.. I dont think you need one that big.. but thats up to you.. how big is your trailer and what kind of load will be on the gen add up all the load and see what you need.. there are plenty of used gens out there
[Re: n20mstr]
#2806137
08/07/20 12:42 PM
08/07/20 12:42 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
Add up the watts of everything you need to run at the same time and the surge wats of things like microwaves in air conditioners definitely come into play well calculating I’m gonna bet you need a 6500 or larger... Your typical RV air conditioner will draw 2500 watt with a 3500 Watt surge that start up microwave is very similar... add everything up it’ll give you what size generator you need.
[Re: boatracer572]
#2806251
08/07/20 06:48 PM
08/07/20 06:48 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Add up the watts of everything you need to run at the same time and the surge wats of things like microwaves in air conditioners definitely come into play well calculating I’m gonna bet you need a 6500 or larger... Your typical RV air conditioner will draw 2500 watt with a 3500 Watt surge that start up microwave is very similar... add everything up it’ll give you what size generator you need. I agree, with everything you got hooked up, I wouldnt doubt you could use the 6500 and the 3500 you already have. Thats allot of power needed at one time, especially with the surge loads.
