hemi spark plug tubes & Seals
#2802644
07/29/20 07:52 PM
07/29/20 07:52 PM
Posts: 15,197 Omaha Ne
TJP
Omaha Ne
Does anyone have a source for better quality spark plug tubes than the factory type junk currently out there?? The existing junk isn't even close to being round with parallel scratches, ripples and the bottoms are about as thick as a matchbook, which in turn distorts easily between the plug and head with or without the washers. I did find one company making a billet tube with steel ends but they are no longer in production due to a lack of demand which is hard to believe> he said they have been getting more and more calls and they are considering making more if the calls continue. Looked like a nice product. LINK TO THEIR SITE with PIC's of THE TUBESWould also be interested in a corresponding set of lower tube seals as well. FYI Aluminum headed motor with edelbrock / mopar heads. It's hard to believe that no one has solved this issue TIA
Re: hemi spark plug tubes & Seals
[Re: 71birdJ68]
#2802811
07/30/20 11:02 AM
07/30/20 11:02 AM
TJP
Omaha Ne
I forgot to mention the engine has the stock stamped steel valve covers so stock length tubes are what is needed. I am told that the lower seals that are available @ multiple sources will fit these heads. The "counterbore" dimensions in the head appear to confirm this. The parallel scratches and ripples in the tubes I am told occur during the forming process which makes sense, but doesn't solve the leakage problem as one cannot expect an o ring to seal against that type of surface. The flimsiness of bottom where the Plug seats is another issue. Does anyone know of a source with better quality?? The gentleman I spoke with yesterday said he would need a minimum of 15 sets ordered and paid for with delivery in 2-3 weeks. SEE PIC. I am half tempted to do so and then resell the other 14 sets
[Re: 68jim]
#2804595
08/03/20 10:09 AM
08/03/20 10:09 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I also went with a slightly fatter o-ring for more crush. The milodon bottom seals help but they are not dry. Need to pull the pkug real fast in order to see the plug with no oil on them.
[Re: 68jim]
#2804742
08/03/20 07:39 PM
08/03/20 07:39 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ii had to double gasket the valve cover so i needed a longer tubes cause the stage V rockers were hitting covers. got a set from Tim Banning at FHO. so far so good! if need be, try a little rtv on bottom of tube
Hell Hath No Fury Like Mine
[Re: sixpacksteve]
#2805547
08/05/20 08:33 PM
08/05/20 08:33 PM
TJP
Omaha Ne
thanks for all the replies. I've ordered in another set of stock ones and will look at them when they get here along with the Milodon inserts I also have a few other ideas I may try. I did contact Tim @ FHO but I'm suspecting his are too long as i ahven't heard back form him. The one set up was so sweet It's hard to believe their no longer making them Thanks again
