Numbers matching ? #2804490
08/02/20 10:27 PM
08/02/20 10:27 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
When you hear the term numbers matching what numbers do they mean and where are they located ?
Re: Numbers matching ? [Re: flatiron] #2804491
08/02/20 10:34 PM
08/02/20 10:34 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
it is going to vary by year & model, a little more on what "WE" are talking about would help?
Re: Numbers matching ? [Re: 6bblgt] #2804515
08/02/20 11:52 PM
08/02/20 11:52 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
It's a 69 Roadrunner 383 4 speed Plum crazy Purple it seems to be in very nice condition. I'm trying to get a handle on the value. I have never really been in a situation where a car like this has been brought to my attention. So I'm very skeptical on what it is and make a educated offer.
Re: Numbers matching ? [Re: flatiron] #2804520
08/03/20 12:02 AM
08/03/20 12:02 AM
AndyF Offline
AndyF  Offline
Numbers matching for a car like that means the stamps on the engine and transmission match the VIN. The fender tag should match the car features and the VIN. The "hidden" VIN numbers should match the VIN tag. Not a lot of fully number matching cars still exist these days since the original engines are often gone but you might get lucky.
Re: Numbers matching ? [Re: AndyF] #2804527
08/03/20 12:39 AM
08/03/20 12:39 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Where are the numbers located and will it be the entire vin
Re: Numbers matching ? [Re: flatiron] #2804578
08/03/20 08:58 AM
08/03/20 08:58 AM
VA
dragon slayer Offline
VA
Partial vin on engine block pad and transmission. Door vin, dash vin are full. Partial vin on the radiator support. That all would be nice if matched with original fender tag, and a broadcast sheet. But the next level of numbers matching and date code matching is all the attached parts. Lots of them in the engine bay, but interior and electrical parts too. Now that may not matter to you, and again prices is the factor. But it is the difference between identical type cars having one worth way more then the other despite matching drive trains.
Also the market now has far more reproduction parts versus OEM original.
Based on the questions your asking, you might want to do some more research or get some one who understands market value. If that matters to you.
You can look at completed Ebay auctions, major auction houses and such. And you can use a tool like Hagerty value to see.
You may be lucky and it is a steal, but more than likely it is not.
Re: Numbers matching ? [Re: dragon slayer] #2804580
08/03/20 09:15 AM
08/03/20 09:15 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
As stated already but know that car has to be a "color change" since Plum Crazy/In-Violet wasn't available for a 69 Road Runner.
Ron
Re: Numbers matching ? [Re: dragon slayer] #2804582
08/03/20 09:20 AM
08/03/20 09:20 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
To start this 69 RR isn't a numbers car if its purple, not available in 69. the Plymouth name is In Violet, not Plum Crazy.
Re: Numbers matching ? [Re: formula_s] #2804850
08/04/20 06:40 AM
08/04/20 06:40 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The question you asked is sort of like that famous one asked to slick Willy. โ€œWhat is the definition of is.โ€๐Ÿ˜‚
Re: Numbers matching ? [Re: flatiron] #2804853
08/04/20 07:18 AM
08/04/20 07:18 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Purple didn't come out till 70, so that there is a knock on value.
Re: Numbers matching ? [Re: 71birdJ68] #2804891
08/04/20 09:20 AM
08/04/20 09:20 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thanks Guys I did find out shortly after the orginal post that In Violet FC 7 was not offered in 69. Like I said I'm a bit skeptical about a True 69 RR 383 4 speed car selling for $16K and looking at the pictures it seems very nice. I get the vibe the owner is trying to unload fast for whatever reason. I will move forward cautiously.
Re: Numbers matching ? [Re: flatiron] #2805436
08/05/20 02:35 PM
08/05/20 02:35 PM
People's Republic of Kali
70runner Offline
70runner  Offline
On FBBO you described this car as "1969 RR clone". 16K suggests it is a Satellite clone. First six VIN digits should tell the story.
