1972 plymouth duster hood scoop installation question #280424
04/07/09 01:31 PM
04/07/09 01:31 PM
sandusky ohio
mopardiebold Offline OP
sandusky ohio
just bought reproduction scoops off of ebay without instruction,i was wondering what scoop is the driver side scoop and passenger side, i think the higher part side goes on the outside of the hood since the hood is taller in the middle,and the scoop should be flat when sitting on the hood,but i want to be completely sure before i drill the holes, any help would be greatly appreciated thanks paul
Re: 1972 plymouth duster hood scoop installation question [Re: mopardiebold] #280425
04/07/09 08:18 PM
04/07/09 08:18 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I looked at a few pictures and it looks like the taller edge is on the outside. It would only make sense, the scoop should be almost level on top when installed. If you need some dimensions on location I can check with a friend who has a 72 Duster with scoops.
Re: 1972 plymouth duster hood scoop installation question [Re: maximus] #280426
04/07/09 11:22 PM
04/07/09 11:22 PM
sandusky ohio
sandusky ohio
yes if you dont mind, thanks Paul diebold
Re: 1972 plymouth duster hood scoop installation question [Re: mopardiebold] #280427
04/08/09 12:30 PM
04/08/09 12:30 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
when you set them on the hood you will see they only look good one way
Re: 1972 plymouth duster hood scoop installation question [Re: west] #280428
04/08/09 01:25 PM
04/08/09 01:25 PM
sandusky ohio
sandusky ohio
ok looks good,iv seen some scoops to close together but yours looks good thanks Paul Diebold
Re: 1972 plymouth duster hood scoop installation question [Re: mopardiebold] #280429
04/08/09 02:22 PM
04/08/09 02:22 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
i have a glass hood so i just put them where i wanted.if you have a steel hood you need to make sure the opening for the air is in between the inner frame of the hood.also the bolts will line up correctly.
