Mopar Differential For Sale - 3rd Quarter #2791113
06/30/20 06:38 PM
06/30/20 06:38 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2791131
06/30/20 06:52 PM
06/30/20 06:52 PM
Indiana
maxie Offline
maxie  Offline
Indiana
A body dana 60 rearend stock width, it was in my demon. Stock perch locations, 35 spline axles with 4.10 gears, 1/2-20 3 inch long screw in studs. Make Williams 1350 yoke The rearend is complete minus the brakes. Will not ship, must be picked up in east central Indiana
Measure 56 1/2 inches from axle face to axle face
$1600 FIRM
PM me through moparts
Scott
THANKS MOPARTS
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2791279
06/30/20 10:59 PM
06/30/20 10:59 PM
Edison, NJ 08817
budman1965 Offline
budman1965  Offline
Edison, NJ 08817
8 3/4 open center section, 742 case with 2.76 gears. Use as is or add a sure-grip unit and new gears. Has small yoke. Asking $150. Must be picked up in central Jersey or possible delivery to Carlisle. Contact Bud Kramden426 at aol.com
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2792228
07/03/20 09:41 AM
07/03/20 09:41 AM
Pa
Hemihead2 Offline
Hemihead2  Offline
Pa
8 3/4” 3.91 ratio 489 case, Sure-grip center section. Nearly new Richmond R/P with new pinion bearings and seal. Cone-type Sure-grip with small yoke. Ready to drop in and go. $850 Plus shipping from Pa, 16602. PM on site or call/text if interested: 814-329-0489
A Body 8 3/4 Reconditined Housing and SBP Axles [Re: Hemihead2] #2792245
07/03/20 10:18 AM
07/03/20 10:18 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a reconditioned 8 ¾ housing from a 1969 Dodge Dart and the stock axles in 5 x 4” (small) bolt pattern.
The axles have had sealed bearings installed and have a few thousand miles on them.
All the dirty work has been done on this housing. It was wire brushed down using electric and air tools. The housing was then cleaned thoroughly inside with a large engine bore cleaning brush, solvent and paper towels and blown dry. Two of the housing studs were replaced due to partial stripped threads. Two of the brake line holding tabs were ground off due to corrosion. The housing was then prepped for POR 15 paints by using POR 15 preparation produces Marine Clean and Metal Ready (rust remover and etching solution). It was then treated to two coats of POR 15 and finally two coats of semi-gloss top coat. See some finished and work in process pictures below.
Price is $500 picked up in CT or plus shipping from CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
8.75 housing 0.5.jpg (840 downloads)
8.75 housing 3.jpg (841 downloads)
8.75 housing 5.jpg (841 downloads)
8.75 axles 1.jpg (838 downloads)
3.23 Ring & Pinion for 489 Case 8 3/4 [Re: Rocket] #2792247
07/03/20 10:21 AM
07/03/20 10:21 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a used 3.23 ring and pinion set from an 8 3/4 differential using a 489 case. Gears are in nice used shape. No pitting, rusting or stripped threads.
Price is $90 shipped in the lower 48 states.
3.23 pic 1.jpg (835 downloads)
3.23 pic 5.jpg (835 downloads)
3.23 pic 10.jpg (834 downloads)
3.23 pic 9.jpg (830 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2793573
07/06/20 06:25 PM
07/06/20 06:25 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
8-3/4 rear end yoke (7260) 10 spline with U-joint straps and bolts. VGC $75 + shipping from 23703.
Direct Connection 8-3/4 adjustable pinion snubber, P/N P3690182, VGC, $55.00 + shipping 23703
Mopar A-body rear shackle bushings, NOS, P/N 1940725, 7/8” diameter, QTY 4. $20.00 + shipping 23703
Mopar rear shock bushings, NOS, P/N 1319902, QTY 2, $20.00 + shipping 23703
jduster340@verizon.net or PM DusterW2
20170102_155957 jpeg.jpg (740 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2793632
07/06/20 08:09 PM
07/06/20 08:09 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
8-3/4 742 case, no caps or adjusters, $50 + shipping 23703
PM DusterW2 or jduster340@verizon.net
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2793633
07/06/20 08:10 PM
07/06/20 08:10 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
I have a pair of used Strange Engineering Hy-Tuff 35 spline axles, excellent condition. These came out of a friend's bracket car. They have 1/2 inch screw in studs (3 inch long), & bearings. One axle measures 22 1/2 inches from the back side of the retainer plate to the end of the splines, the other measures 23 1/2 inches. The splines are 3 1/4 long. Asking $275.00 for the pair plus actual shipping..
PM me here (1st choice), or e-mail me at duster doug at comcast dot net..
Thanks for the ad Moparts!!!
"I've upped my horsepower, so...... UP YOURS!!!"
9 1/4" Rear Axle & 44 Front [Re: DusterDog] #2794500
07/08/20 08:47 PM
07/08/20 08:47 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Complete 9 1/4" Rear Axle w/Sure-Grip And A Complete Dana 44W/ Open Diff, Was In A 1989 Ram Charger And Both Have w/3.23s $400 For Both, No Shipping! P.M. Me Thanx Moparts!
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2797895
07/17/20 02:13 PM
07/17/20 02:13 PM
OH
junkyardmaxie Offline
OH
new MOTIVE gear set SOLD AT SUMMIT $240 plus tax ,street strip NEW ring and pinion 456-1 fits #489 case $140 plus shipping great deal if you can use it
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2797920
07/17/20 03:05 PM
07/17/20 03:05 PM
southwest pa
dan345 Offline
dan345  Offline
southwest pa
AXEL BEARING Green bearing kit part number RP400 $25.00 plus postage, for more info contact DAN at724 858 6662 or PM
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2797931
07/17/20 03:16 PM
07/17/20 03:16 PM
southwest pa
dan345 Offline
dan345  Offline
southwest pa
INPUT SHAFT BEARING A833 N.O.S. front input shaft bearing part number 3410048, MRC number 307SG14 $40.00 each for more info contact DAN at 724 858 6662 or PM ( TWO AVAILABLE )
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2797945
07/17/20 03:29 PM
07/17/20 03:29 PM
southwest pa
dan345 Offline
dan345  Offline
southwest pa
PINION CRUSH COLLAR N.O.S. Pinion crush collar for a 489 case with the tapered pinion shaft part number 2931687 $15.00 each plus postage ( TWO AVAILABLE ) for more info contact DAN at 724 858 6662 or PM
Re: Mopar Differential For Sale - 3rd Quarter [Re: dan345] #2803161
07/31/20 06:41 AM
07/31/20 06:41 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
8.75 shortened rear end set up for ladder bars and coil over shocks. 742 Carrier with a 4.30 Richmond gear. Spool and Mark Williams bearing cap for strength. Dutchman axles with Mopar Green bearings. The housing is 46" from outside flange to flange. 45." to the inside. The Ladder bar brackets are 22" center to center. This is a strong rear end and has taken my 3500 lb car 10.38 . The rear works well and is ready to install. The only reason I am selling it is because I went to a Strange Dana 60 . 1150.00 . Message me here or text questions. 757-715-2198. Joe Less
6.51 @104.8
Re: Mopar Differential For Sale - 3rd Quarter [Re: Kindafast] #2805501
08/05/20 05:53 PM
08/05/20 05:53 PM
Long Island, NY
Jstern Offline
Jstern  Offline
Long Island, NY
10 spline coarse yoke for 8 3/4 rear. 7260. No straps included. $50+ s&h
mOPAR yOKE (1).JPG (312 downloads)
mOPAR yOKE (3).JPG (313 downloads)
Re: Mopar Differential For Sale - 3rd Quarter [Re: Jstern] #2806820
08/09/20 12:06 PM
08/09/20 12:06 PM
Ill
SMILINJOE Offline
SMILINJOE  Offline
Ill
A Body 8 3/4 shorted to 49” flange to flange. Has Dr Diff big bolt pattern axels.
Perches set up for mini tub moved in to frame using relo kit.
$480
Located near Chicago.
Re: Mopar Differential For Sale - 3rd Quarter [Re: moparts] #2806835
08/09/20 12:56 PM
08/09/20 12:56 PM
southwest pa
dan345 Offline
dan345  Offline
southwest pa
YOKE Used original 8 3/4 course spline yoke, $40.00 plus postage, for more info contact DAN at 724 858 6662 or PM
Re: Mopar Differential For Sale - 3rd Quarter [Re: junkyardmaxie] #2807337
08/10/20 03:38 PM
08/10/20 03:38 PM
E
earlymopar Offline
earlymopar  Offline
E
Delete
Re: Mopar Differential For Sale - 3rd Quarter [Re: earlymopar] #2807459
08/10/20 09:04 PM
08/10/20 09:04 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
I have 3 rear end housings for 8 3/4 center sections for sale.
#1 housing is 53 1/4" end to end for 1962 1963 and 1964 MAX WEDGE B Bodies $200.00
#2 housing is 57 7/8" end to end for 1971 1972 1973 1974 B Bodies $100.00
#3 housing is 56 3/4" end to end for 1965 1066 1967 1968 1969 C Bodies with backing plates and axles the housing is rusty $100.00
The prices do not include shipping from northwest Indiana.
Thanks!
