EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? #280172
04/07/09 05:22 AM
04/07/09 05:22 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
I have an original hemi shaker base and adapter ring here. What's queer is the nut inserts for the shaker bubble, they are on the top of the ring and instead of being #10-24 they are for a 1/4"-20 bolt. The nut insert is the same as the one used on the 2 mounting feet on the bottom of the base.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: HEMICUDA] #280173
04/07/09 12:22 PM
04/07/09 12:22 PM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Anyone?
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: HEMICUDA] #280174
04/07/09 12:26 PM
04/07/09 12:26 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, it's common, my six pack cuda was the same way. Wasn't exactly condusive to keeping your Shaker Bubble crack free around the bolt holes.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: ScottSmith_Harms] #280175
04/07/09 12:45 PM
04/07/09 12:45 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have one, actually two, but I was told they were a one day production mistake.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: mccannix] #280176
04/07/09 12:50 PM
04/07/09 12:50 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just one example of why you can't always use blueprints and factory documentation as the "end all" to how these cars were built. Preproduction and running production changes (and mistakes) happened, never say never
BTW, the SPD of the car my example came on was 2/12/1970, LA car.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: ScottSmith_Harms] #280177
04/07/09 01:00 PM
04/07/09 01:00 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
No arguing that tag Scott..it's a nice one.
I actually like the fact that the adapters with the top welded nuts make the scoop sit 1/4 inch higher
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: mccannix] #280178
04/07/09 07:03 PM
04/07/09 07:03 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
1/4-20 bolts on an unrestored 1970 Hemi Cuda
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: MMC Detroit] #280179
04/07/09 08:15 PM
04/07/09 08:15 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Original square nuts used by Fram on shaker assembly, 10-24 on the left, 1/4-20 on the right.
Adapter rings were supposed to receive seven 10-24 nuts spotwelded on the bottom as per factory blueprint.
The larger opening 1/4-20 nuts were for use on the 340, 440-6, and Hemi feet brackets.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: mccannix] #280180
04/07/09 08:17 PM
04/07/09 08:17 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
from the print.
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: MMC Detroit] #280181
04/20/09 12:45 AM
04/20/09 12:45 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Just curious, how do you know that car was built that day? (the text in the photo)
Re: EBODY SHAKER ADAPTER RING NE1 SEEN THIS BEFORE? [Re: Alaskan_TA] #280182
04/20/09 01:07 AM
04/20/09 01:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Barry, Dave's on the road and won't likely see this for a few days. I can only surmise that it relates to the Scheduled Production Date, and not the "Actual" production date.
