Torque tube UPDATE #2801210
07/26/20 06:12 AM
07/26/20 06:12 AM
Greenville, PA
redraptor Offline OP
Greenville, PA
After nearly a year of debate, I finally convinced my buddy to bring his Marlin out to my place and replace the broken bellhousing. I lent him my trailer and off we went.
https://board.moparts.org/ubbthread...kool-me-on-torque-tubes.html#Post2682486
Re: Torque tube UPDATE [Re: redraptor] #2801211
07/26/20 06:18 AM
07/26/20 06:18 AM
Greenville, PA
Greenville, PA
I took Orange_Crush's approach and bought an extra stand and put them on a dolly. I used my tranny jack to support the front and rolled everything back. Only thing in the way was the muffler.
Re: Torque tube UPDATE [Re: redraptor] #2801213
07/26/20 06:30 AM
07/26/20 06:30 AM
Greenville, PA
Greenville, PA
He also bought a clutch disc and pressure plate. He had talked about clutch being a [censored] size but we didn't realize that it also works backwards of a normal clutch. The pedal is cable actuated with a huge extension spring to keep tension on the clutch fork and pressure plate fingers for engagement. runaway
I did manage to coax the engine back to life for a few minutes but it had a coolant leak in the exhaust manifold area so no test drive at this time.
Re: Torque tube UPDATE [Re: redraptor] #2801616
07/27/20 08:03 AM
07/27/20 08:03 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Wow, an AMC torque tube! I read through the old thread from last year. Very cool - learn something new every day!
In case anyone thought torque tube technology is outdated, our Aston Martin uses a cast aluminum torque tube around a carbon fiber driveshaft, rigid from engine to transaxle.... fun stuff.
- Art
1965 Satellite hardtop 361/2bbl, console 727, open 2.76
1967 Satellite convert 383/4bbl, column 727, open 3.23
1975 Maserati Bora, US spec 4.9L DOHC hemi V8, 5-spd ZF man
1977 Maserati Khamsin, Euro spec 4.9L DOHC hemi V8, 5-spd ZF man
1982 Alfa Romeo GTV6, 2.5L SOHC hemi V6, 5-spd man transaxle
2007 Aston Martin DB9, 6.0L DOHC V12, 6spd man transaxle
Re: Torque tube UPDATE [Re: 67SATisfaction] #2801640
07/27/20 08:58 AM
07/27/20 08:58 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I imagine the Aston has an independent rear suspension, which doesn't add to the unsprung weight.
