Re: Mopar 345 crate
[Re: Dragula]
#2801649
07/27/20 10:24 AM
07/27/20 10:24 AM
Posts: 2,255 IL
furious70
IL
why not just get another OEM K member for your car or maybe buy the QA1 K that uses other stock components if you don't want to use a plate for the 5.7?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Mopar 345 crate
[Re: wyldebill]
#2801959
07/28/20 12:21 AM
07/28/20 12:21 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Re: Mopar 345 crate
[Re: L4staero]
#2802919
07/30/20 02:20 PM
07/30/20 02:20 PM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
Tune with HP Tuners. Diablo seems to brick the PCM Is there a way to use hp tuners without buying credits?
Re: Mopar 345 crate
[Re: wyldebill]
#2803375
07/31/20 05:51 PM
07/31/20 05:51 PM
Posts: 146 Australia
L4staero
Australia
Tune with HP Tuners. Diablo seems to brick the PCM Is there a way to use hp tuners without buying credits? You can use the scanner for free. If you need to tune the PCM and modify the settings you need to buy credits once to license the PCM
