BB fuel pump push rod again ? #2800733
07/24/20 07:34 PM
07/24/20 07:34 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Does anyone have any input on a source for a BB fuel pump push rod that will last ??? I have sent board member MCcannix ? a PM asking for price and delivery estimate time wise. With him being in Cananda, I am trying to establish a backup plan in case the timing with him doesn't work out.
I looking for any other recommendations good or bad ( so I know where not to go).
I just removed my second comp cams failed push rod from a customers motor and time is of the essence.
Any input is appreciated.
Thanks beer
Re: BB fuel pump push rod again ? [Re: TJP] #2800844
07/25/20 01:18 AM
07/25/20 01:18 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have had good luck with the ones from Mancini Racing...
They also carry the steel rod from Hughes Engines.
Here is the link..
https://www.manciniracing.com/stfupupub426.html
Just my $0.02... wink
Re: BB fuel pump push rod again ? [Re: Sinitro] #2800913
07/25/20 10:26 AM
07/25/20 10:26 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Thank you, Due to the border issue with Canada (closed & delays shipping) that may be an alternative.
Anybody else, good or bad ??
beer
Re: BB fuel pump push rod again ? [Re: TJP] #2800946
07/25/20 11:32 AM
07/25/20 11:32 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
I spoke with a sales guy at Mancini. He said that had a bad batch a couple of years back but no returns since and they are getting them from moroso. he also said they do not stock the ones from Hughes frown
One wouldn't think it would be that hard (no pun intended) to make a flippin' fuel pump push rod.
Sinitro, how many have you used from Mancini? How many miles on them ?? and when did you buy them or over what period of time ??
Sorry for all the questions but I really don't want to roll the dice as it is a customers car and I don't need the headache of a torched motor due to a 25.00 junk part.
Any other input PLEASE !!!
Re: BB fuel pump push rod again ? [Re: TJP] #2801008
07/25/20 01:36 PM
07/25/20 01:36 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I have some NOS ones. Shoot me a PM
Re: BB fuel pump push rod again ? [Re: T2R9] #2801017
07/25/20 02:01 PM
07/25/20 02:01 PM
South San Francisco, Ca
70sixpkRT Offline
70sixpkRT  Offline
Are the NOS ones better than Hughes? I like to have an extra one.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: BB fuel pump push rod again ? [Re: TJP] #2801090
07/25/20 05:27 PM
07/25/20 05:27 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Find an old used oem that still measures the right length and it will last forever.
I would be curious to know if the worn out ones were used with a high pressure pump or a standard pressure pump. Which end wears down? Cam end, pump end, both ends?
Re: BB fuel pump push rod again ? [Re: GomangoCuda] #2801124
07/25/20 07:24 PM
07/25/20 07:24 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Standard factory pump and cam end on all three comp cams Push rods, 2 different versions down
Re: BB fuel pump push rod again ? [Re: TJP] #2801128
07/25/20 07:30 PM
07/25/20 07:30 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
This hardened one left me on the side of the road. After that I bought all the NOS ones I could find. I won't run an aftermarket one regardless of the name.
Re: BB fuel pump push rod again ? [Re: T2R9] #2801133
07/25/20 07:35 PM
07/25/20 07:35 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Can I get a trade in ?? I have one just like that laugh2 and you have $$ beer
Re: BB fuel pump push rod again ? [Re: TJP] #2801259
07/26/20 10:25 AM
07/26/20 10:25 AM
Niles , Ohio
therocks Offline
Its Lost
therocks  Offline
Its Lost
Niles , Ohio
Member Mccanix is his name I believe has nos ones.Great price and ships fast. Many member have bought them and no problems.Ive had one in my 440 for like 3 years or so.Great guy to deal with.Oh yeah look at some past posts you will find his name and as said lots here have used his rods.Rocky
Chrysler Firepower
Re: BB fuel pump push rod again ? [Re: therocks] #2801269
07/26/20 10:51 AM
07/26/20 10:51 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Have one of his on both my cars....0 issues. Have a couple of extras as well....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: BB fuel pump push rod again ? [Re: JMCFAN] #2801275
07/26/20 11:01 AM
07/26/20 11:01 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I prefer a good old stock rod to the newer stuff. you just don't know what your getting with the newer parts anymore..
Re: BB fuel pump push rod again ? [Re: T2R9] #2801317
07/26/20 12:49 PM
07/26/20 12:49 PM
70sixpkRT Offline
70sixpkRT  Offline
Sent pm.
4-speed
3:54 Dana
Re: BB fuel pump push rod again ? [Re: lewtot184] #2801322
07/26/20 12:56 PM
07/26/20 12:56 PM
am I ok? blush
Re: BB fuel pump push rod again ? [Re: RapidRobert] #2801344
07/26/20 01:40 PM
07/26/20 01:40 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by RapidRobert
am I ok? blush
run a fine file across the side of the rod (not on the bearing surface that contacts the block). if the file can't mark or remove metal it's ok.
Re: BB fuel pump push rod again ? [Re: 70sixpkRT] #2801345
07/26/20 01:42 PM
07/26/20 01:42 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Due shipping delays ( borders closed) I scored a couple from T2R9.
And Robert I don't know. The ones I previously had were bought in 93 or so and were standard Mopar replacements in a white package with a part #. Not the like the ones you have pictured. Hopefully someone else will chime in to say yay or nay beer
Re: BB fuel pump push rod again ? [Re: lewtot184] #2801347
07/26/20 01:44 PM
07/26/20 01:44 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
am I ok? blush
I'm not sure that's an adequate test as the failed ones from comp passed that test shruggy beer
Re: BB fuel pump push rod again ? [Re: TJP] #2801378
07/26/20 02:57 PM
07/26/20 02:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
am I ok? blush
I suppose the only true test is to test the Rockwell and who has the equipment to do that? anyhow it's worked for me.
Re: BB fuel pump push rod again ? [Re: GomangoCuda] #2801552
07/26/20 11:14 PM
07/26/20 11:14 PM
People's Republic of Kaliforni...
70runner Offline
70runner  Offline
Used OE works great or NOS/McCannix. On my daughters 69 RT the cam end of a repro wore 1/4" after about 4hrs of driving. I wouldn't trust any of the repros.
