Re: GMG Hellcat Dart back up for sale
[Re: LA360]
#2800514
07/24/20 08:55 AM
07/24/20 08:55 AM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Tough crowd ..
I sense a fair amount of jealousy ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: dOc !]
#2800556
07/24/20 10:46 AM
07/24/20 10:46 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
ANYONE know why RR opted for a PowerSlide instead of the std 8 speed ? I doubt that RR knows the difference. Since this is a race type build with good power and light weight the glide makes sense. Plus there are tons of parts and vendors for them in the aftermarket, specifically converters. My guess is that whoever was in charge of the build called one of the sponsors of the show and told them what they were building and they needed a transmission and a week later it all showed up on a pallet.
[Re: bigdad]
#2800558
07/24/20 10:51 AM
07/24/20 10:51 AM
justinp61
W. Kentucky
Tough crowd ..
I sense a fair amount of jealousy ? Not here, I just don't like Rawlings. He tries to come across as gear head but in reality makes a a$$ out of himself. Then there's his attitude and mouth. He should stick to writing the checks and painting his nails.
[Re: dOc !]
#2800560
07/24/20 10:54 AM
07/24/20 10:54 AM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
ANYONE know why RR opted for a PowerSlide instead of the std 8 speed ? YES.....At 300ft off the line, the PG is quicker than the 727 in the same car.....
[Re: justinp61]
#2800565
07/24/20 10:57 AM
07/24/20 10:57 AM
Posts: 31,061 Oregon
AndyF
ANYONE know why RR opted for a PowerSlide instead of the std 8 speed ? I doubt that RR knows the difference. Since this is a race type build with good power and light weight the glide makes sense. Plus there are tons of parts and vendors for them in the aftermarket, specifically converters. My guess is that whoever was in charge of the build called one of the sponsors of the show and told them what they were building and they needed a transmission and a week later it all showed up on a pallet. I don't have any experience with the Hellcat engine in a drag car but my guess is that the torque curve is big enough that it would work well with a two speed transmission for drag racing. It would also probably work okay with a three speed transmission. I doubt many folks are going to want to go racing with a factory 8 speed. From what I can see in the pictures, whoever picked the parts for the car did an okay job. For $20K the Hellcat engine is probably a bit more expensive than a more typical 505 inch big block that makes roughly the same power but it isn't out of sight. A 700 hp big block will cost around $15K to build if you start from scratch so it isn't crazy to use the Hellcat engine. If a person wanted to duplicate this car they could probably pick up a rolling chassis for around $10K and put the $20K engine in it and be ready to go down the track for $35K total after replacing some parts and fixing the usual things that are wrong with a used race car.
[Re: justinp61]
#2800574
07/24/20 11:11 AM
07/24/20 11:11 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Tough crowd ..
I sense a fair amount of jealousy ? Not here, I just don't like Rawlings. He tries to come across as gear head but in reality makes a a$$ out of himself. Then there's his attitude and mouth. He should stick to writing the checks and painting his nails. actor, playing a part .. I knew him before the glam and glitz, always a bit exuberant but, decent fella ..He went from wealthy to rich now, so who knows ? Since I left Texas I have lost touch with that group
[Re: bigdad]
#2800581
07/24/20 11:26 AM
07/24/20 11:26 AM
justinp61
W. Kentucky
Tough crowd ..
I sense a fair amount of jealousy ? Not here, I just don't like Rawlings. He tries to come across as gear head but in reality makes a a$$ out of himself. Then there's his attitude and mouth. He should stick to writing the checks and painting his nails. actor, playing a part .. I knew him before the glam and glitz, always a bit exuberant but, decent fella ..He went from wealthy to rich now, so who knows ? Since I left Texas I have lost touch with that group If part of the script is making him look like an a$$ he does a darn good job, acting or not, LOL. He's made a ton of money so my hats off to him for his success.
[Re: dOc !]
#2802163
07/28/20 02:55 PM
07/28/20 02:55 PM
Posts: 1,553 Michigan
Kiddart
i don't think money would have kept him at gmg
Thank you Kiddart
