68 Satellite, 8 3/4 or Dakota 9 1/4?
#2799509
07/21/20 07:07 PM
07/21/20 07:07 PM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have an very rusty 68 Satellite. /6, radio delete, column auto, and noisy 7 1/4. The old car is not much, barely road worthy to be honest, but is fun to beat around in. I have enough parts to build an 8 3/4 for it including some 3.91s. I would need to buy a few things and would need to move the spring perches on the housings I have, but I think I could do the deal for $200 or so.
I can get a complete Dakota 3.55 rear (maybe even with a Sure-Grip) out of a yard for $150 or so. I know I would need to do something with the U joint, spring perches, and axle studs. This swap I haven't done before, so what else would be needed?
Which way would you go? I think that I would lean towards the easiest install if there were not much money difference. Any input here would be appreciated. Especially from anyone who has done the Dakota diff swap.
Thanks!
Master, again and still
Re: 68 Satellite, 8 3/4 or Dakota 9 1/4?
[Re: A990]
#2799542
07/21/20 08:31 PM
07/21/20 08:31 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Newsflash! A couple hundred dollars ain't $hit when it comes to vintage Mopars. I spend more than the cost of this differential project on tires every year or so on the Cuda.
I get as much interest in the rust bucket from people as I do with my HemiCuda. I take it to events and stuff almost as often as the Cuda because I have about as much fun and don't have to worry about anything happening to it. Owning it the last couple of years has been a real eye opener.
