Re: The FCA bumper to bumper warranty?
[Re: dOc !]
#2799415
07/21/20 02:45 PM
07/21/20 02:45 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I do not believe the warranty will cover tires . The best fix is a patch/plug .( patch plug all in one ) . Do note that the tire will no longer be speed rated . The best fix if you are planning on setting any land speed records is a new tire . If it were mine ,and a repairable puncture , I would get that fix .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: moparx]
#2799427
07/21/20 03:14 PM
07/21/20 03:14 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
HaY DoC ! if i had YoUr BuX, i would BuRn mine ! just pony up for a flat repair and quit being so ChEeP !!!!! mopX.. those Asian babes that you allege I have are vErY expensive! BTW ... ur up awfully early from yur afternoon nap 😴
[Re: doctor_mopar]
#2799430
07/21/20 03:19 PM
07/21/20 03:19 PM
dOc !
Florida STAYcation
I do not believe the warranty will cover tires . The best fix is a patch/plug .( patch plug all in one ) . Do note that the tire will no longer be speed rated . The best fix if you are planning on setting any land speed records is a new tire . If it were mine ,and a repairable puncture , I would get that fix . DocMop.... so splain to me the effective service diffs between a plug, a inside patch and a P P ... ! Ever hear of a plug getting spit out ?
[Re: Mastershake340]
#2799433
07/21/20 03:25 PM
07/21/20 03:25 PM
dOc !
Florida STAYcation
They usually try to peddle you a tire and wheel warranty at the dealer when you buy a new car. Bumper to bumper warranties don’t cover wear items like tires, brakes and windshield wiper blades. Interesting Ms ... I did a short financing situation where they doubled the b2b ... I’ll have to check. But my FIRST AND ONLY dealership experience was not very positive
[Re: dOc !]
#2799492
07/21/20 05:52 PM
07/21/20 05:52 PM
doctor_mopar
Slidell, La.
A repair is only as good as the materials and workmanship . A patch is considered better than a plug, but leaves the hole open , and moisture can get in between the plies and cause separations and problems over time, also you get get problems with separation with plugs . Popping out is just a bad job , and has been known to happen . A patch plug will seal the liner from the inside , and fill the hole to keep moisture out .
[Re: doctor_mopar]
#2799621
07/22/20 04:43 AM
07/22/20 04:43 AM
Posts: 5,646 Port Huron, Michigan
MI_Custumz
We bought the Mopar extended warranties on the last 4 vehicles we owned. I've had wheel bearings, intake manifold, radiator, rear hatch motor, starter, and a few other things replaced under the warranties. $100 deductible. Can't buy the parts for that price. As far as the tires, they are not covered. However, I have bought several tires at Discount Tire over the years and they patched a hole the wife had in her tire once. It was the original tire and not bought from them. They did it at no cost.
[Re: mgoblue9798]
#2799689
07/22/20 10:16 AM
07/22/20 10:16 AM
dOc !
Florida STAYcation
I hear ya bugEye ... but that Doc from Slide Into Hell has a point toooo ! I’ve never had a problem with using a plug before BUTTTT.... I’ve never considered a near 160 mph HIGH GEAR PRESS in my last daily driver ..... A Grand Carrotvan...
