Re: Forged BB crank ID
[Re: RMCHRGR]
#2798650
07/19/20 05:03 PM
07/19/20 05:03 PM
Posts: 6,279 nowhere
Sniper
nowhere
There was a point when the thrust bearing diameter changed, got larger. Maybe that's what you are seeing. If it where a cut down 440 crank you wouldn't see stock (I assume 400) pistons a mile down the hole, they'd be pop ups and hitting the head. http://440source.com/bearings.htm
[Re: RMCHRGR]
#2798651
07/19/20 05:05 PM
07/19/20 05:05 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I am wondering if the reason there is so much more material there is because it might be a 440 crank that had the journals cut down to fit into the 400? I'm thinking if it was a cut down RB crank there would be a radius instead of an undercut where the journal meets the thrust face. '74 and later BB cranks had a larger 3.780" diameter thrust surface. If still in doubt, measure the stroke.
[Re: RMCHRGR]
#2798797
07/20/20 03:20 AM
07/20/20 03:20 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Earlier manuals 400s still got forged crank. So... it could be?
[Re: Sniper]
#2798869
07/20/20 10:36 AM
07/20/20 10:36 AM
Posts: 1,892 Spahn Ranch
RMCHRGR
Spahn Ranch
There was a point when the thrust bearing diameter changed, got larger. Maybe that's what you are seeing. If it where a cut down 440 crank you wouldn't see stock (I assume 400) pistons a mile down the hole, they'd be pop ups and hitting the head. http://440source.com/bearings.htm Had to go back and re-check the deck height math but this is correct. The piston C.H. looks to be the typical 1.813" measured from the center of the wrist pin to the top of the piston. So 3.38"/2 = 1.69" + 6.358" + 1.813" = 9.861. Then 9.980"- 9.861" =.119" below the deck which seems on par for a late '70s 400. Guess I did it wrong the first time because I would have realized there is no physical way this combination of parts would have worked with a 3.75" stroke. Always a plus to know what you actually have. Seems like the chances of it being an original forging from 1977 are slim but whatever, it's a factory forged crank in decent enough shape. Thanks again for the replies.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2798894
07/20/20 11:59 AM
07/20/20 11:59 AM
John_Kunkel
Rio Linda, CA
It's been reported that some HD manual trans trucks with the 400 got forged cranks well into the seventies.
[Re: NachoRT74]
#2798925
07/20/20 01:23 PM
07/20/20 01:23 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Earlier manuals 400s still got forged crank. So... it could be? I have a 1976 400 out of a 4x4 4 wheel drive stick shift pickup that has a thin balancer on the forged steel crankshaft I bought it for the block only, I may still have that crank, it spun a rod bearing or two and didn't look like it hurt the crank at all If you want me to look at it and maybe post a picture of it I will
[Re: John_Kunkel]
#2799002
07/20/20 03:59 PM
07/20/20 03:59 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
It's been reported that some HD manual trans trucks with the 400 got forged cranks well into the seventies. Several years ago I pulled a '78 400 out of a pickup truck with a manual trans. Had a steel crank and the backside of the bearings were dated '78.
[Re: vdriver]
#2799293
07/21/20 10:14 AM
07/21/20 10:14 AM
RMCHRGR
Spahn Ranch
It's been reported that some HD manual trans trucks with the 400 got forged cranks well into the seventies. Several years ago I pulled a '78 400 out of a pickup truck with a manual trans. Had a steel crank and the backside of the bearings were dated '78. Guess it's possible it's 400 forged crank? The truck was 2wd and originally a 318. Would 2WD, 4 speed big block trucks been equipped with a forged crank or was that a HD/4x4 application only? Seems reasonable to presume the engine came out of a BB manual trans truck since it had the deep, rear sump pan though I have no idea if that was original to this particular motor or not. The truck was from out in Oregon which somehow retains more '70s trucks per capita than anywhere else on the planet so finding the motor and/or parts was probably fairly easy. Original or not though, the motor was a strange buildup. There were some decent parts in it - aforementioned steel crank, nice recon'd rods with ARP bolts, milled 452 heads with positive seals and M.P. valves, .484" purple cam, Performer RPM intake, long tube headers, double roller timing chain, "Hemi" mechanical fuel pump, windage tray, HV oil pump and HD shaft...your basic '80s style "Mopar Performance" recipe street motor. Unfortunately the guy kept the stock, low compression pistons in it and put it in front of a wide-ratio, granny first gear NP 435 with 3.23 rear gears which leaves you to scratch your head. The thing it did best was drink gas. It ran OK after a lot of tinkering but it was basically doomed from the start with the low compression pistons.
[Re: vdriver]
#2799355
07/21/20 12:30 PM
07/21/20 12:30 PM
John_Kunkel
Rio Linda, CA
Good to know, latest I'd ever heard before was '76 but always suspected the forged units went up to the end of BB production.
