Re: 66 Hemi block
[Re: cudaman1969]
#2796371
07/14/20 01:56 AM
07/14/20 01:56 AM
Posts: 10,128 A Red State
SNK-EYZ
A Red State
I'm no expert, but I thought that they didn't even stamp a VIN number in the block until the 68 model year.
They were still using 66 casting date blocks into 68, or at least that's what I've been told.
66 and 67 model year cars wouldn't have the VIN stamped into the block, just machining dates I believe.
Re: 66 Hemi block
[Re: cudaman1969]
#2796433
07/14/20 10:26 AM
07/14/20 10:26 AM
Posts: 10,703 North Dakota
6PakBee
North Dakota
If the block has no numbers stamped anywhere would it be considered a ‘warrenty’ block? I agree with gtx6970, it's an over the counter or service block. All the warranty engines I've ever seen have been a minimum of a short block and have the warranty tag riveted over one of the casting plug holes. This is NOT a Hemi block but it would be similar,
Re: 66 Hemi block
[Re: 6PakBee]
#2796452
07/14/20 11:26 AM
07/14/20 11:26 AM
Posts: 2,366 Wheatfield, NY
Cuda340
Wheatfield, NY
Didn't they put numbers around where the bellhousing mates to the block on the topside in some cases?
Re: 66 Hemi block
[Re: Cuda340]
#2796474
07/14/20 11:57 AM
07/14/20 11:57 AM
6PakBee
North Dakota
Didn't they put numbers around where the bellhousing mates to the block on the topside in some cases? I believe you are referring to the early '68 VIN location.
Re: 66 Hemi block
[Re: gtx6970]
#2796569
07/14/20 03:36 PM
07/14/20 03:36 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
Just guessing here, but if there are no numbers on the top machined pad. Im thinking over the counter block . Or what some call a warranty block
And , Yes there are no VIN numbers stamped in till 1968 vehicles Could someone have milled the top China rail and removed original numbers? Unintentionally or intentionally? I mean people do all kinds of crazy stuff to Hemi blocks.
Re: 66 Hemi block
[Re: autoxcuda]
#2796627
07/14/20 05:41 PM
07/14/20 05:41 PM
6PakBee
North Dakota
Possible. If it is a '66 casting and there is no VIN stamped on the top rear, then I would think had the engine been in a car it would had to have been either a '66 or '67. If so the pan rail should have the build date stamped on it. When the OP said there were no numbers "anywhere" I took this to mean the pain rail was not stamped also. But that is an assumption on my part.
Re: 66 Hemi block
[Re: 6PakBee]
#2796754
07/14/20 11:25 PM
07/14/20 11:25 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
After cleaning the pad found these. Where are those numbers on your block?
Re: 66 Hemi block
[Re: cudaman1969]
#2796852
07/15/20 09:46 AM
07/15/20 09:46 AM
6PakBee
North Dakota
After cleaning the pad found these. Where are those numbers on your block? Pan rail "ear", rear, starter side. The "WT" is for water test, the "F", don't have a clue.
Re: 66 Hemi block
[Re: 6PakBee]
#2796860
07/15/20 10:23 AM
07/15/20 10:23 AM
cudaman1969
fredericksburg,va
Thanks, only this. As you can see ear was broke off at one time, I’ll cut and weld back correct.
Re: 66 Hemi block
[Re: mattsmopars]
#2796949
07/15/20 12:41 PM
07/15/20 12:41 PM
cudaman1969
fredericksburg,va
1/27/66 date on block. No numbers on the bell housing lip like my 68 block has. Went over the whole thing with a magnifying glass. I’ve had warranty blocks it has no rivet hole for the blue tag. So I’m guessing an over the counter block. Bad part it’ll have 2 sleeves and punched .060
Re: 66 Hemi block
[Re: mattsmopars]
#2797034
07/15/20 03:08 PM
07/15/20 03:08 PM
6PakBee
North Dakota
The WT stamp on the top pad is more common on blocks used in cars after 1967. I would question that.
Re: 66 Hemi block
[Re: cudaman1969]
#2806795
08/09/20 10:44 AM
08/09/20 10:44 AM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
On the bottom of the pan rail it is clean with no Machining Number or Assembly Number or year Identification Letter, i would be looking for the rivit or the rivit hole to see if it was a Warrenty Block. No Year Identification on the top pad also make one thing to look for the rivit or rivit hole.
1971 HEMI E BODY REGISTRY
