Re: DRAG WEEK RAD/COOLING PKG
[Re: A/MP]
#2796184
07/13/20 02:36 PM
07/13/20 02:36 PM
Posts: 10,022 MN
JERICOGTX
MN
HEMI Joel uses a Meziere pump, on his 392 HEMI, as do many others. We had no issues running it in 2018. Stuff the biggest aluminum radiator you can fit in the car as well. Never know when the route will send you through rush hour traffic.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2796237
07/13/20 04:59 PM
07/13/20 04:59 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
My system is adequate but not ideal. My radiator core is 22x19 and I run dual electric fans from an Intrepid. I run a Meziere 35GPM pump. Other than chicago gridlock in 2015 I have never had to pull over on drag week due to overheating but there has been plenty of close calls of running 210-215 on the highway with lots o traffic. My car will gain 5-10* if you get anywhere near truck traffic on the highway.
Cooling upgrades is on my list for every drag week but I usually don't get it done lol. The Meziere pump on a small block presents some clearance challenges with electric fans.
68 Barracuda Formula S 340
[Re: NoFrills]
#2796334
07/13/20 10:37 PM
07/13/20 10:37 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I couldn't be happier with the cooling system in my hot rod. It's a 468-in, 13 to 1 Hemi, and a drag week 2018 we were in South Carolina and Georgia. It must have been about a hundred degrees in the Sun, and sitting in traffic for extended periods the highest it ever got was about 185. I think that the key is to have lots of radiator, lots of water flow, and lots of air flow. The car has a big aluminum radiator, 55 GPM messier pump, and a single dorman electric fan that was made for a Chevy HHR that I got for about 50 bucks at RockAuto. I ripped the shroud off of it and run it with no shroud. Its got the radiator mounted water pump and I built a reverse cooling system by running a pair of - 12 lines from the outlet of the pump into the heads. Then from the block, a pair of - 20 lines into the top of the radiator.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Bad340fish]
#2796696
07/14/20 09:19 PM
07/14/20 09:19 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
To pick up a little room I did a little welding on on the timing cover around the water holes. Then milled off the pump recess on the cover to make it flat and a back plate is not needed for the Meziere pump. I also welded up the fuel pump hole at the same time. This mod gave me about 3/4" more room
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2796700
07/14/20 09:38 PM
07/14/20 09:38 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
I never had cooling problems, ever, until I built a 605 Hemi with a Mega block....I was using a BeCool 31x19 with 1" double row tubes p#62087 in combination with a Mezeire 35gph water pump and a set of flex-a-lite dual 12" fans w/2500cfm...That worked great for many years until this big iron monster.....
I switched out the fans to BeCool dual 13" 10 blade fans for 3560cfm and now swapped the 35gph water pump for a 55gph ater pump.....We will see. When I kicked the fans on the first time, they blew both fuses and I had to then upgrade my 100 amp alternator to a 140 amp to get any real voltage at idle....Its been a struggle with the hood on to stay cool...typically gets to 215-217ish....No likey....
Maiden voyage tomorrow maybe....
On my race car, I run a mechanical setup, and I switched from a stock water pump to one of those FlowKooler deals, that dropped over -10 out of the car temp and it never sees above 195 on the hottest days round robin...
[Re: Just-a-dart]
#2796817
07/15/20 07:28 AM
07/15/20 07:28 AM
Bad340fish
Tulsa OK
To pick up a little room I did a little welding on on the timing cover around the water holes. Then milled off the pump recess on the cover to make it flat and a back plate is not needed for the Meziere pump. I also welded up the fuel pump hole at the same time. This mod gave me about 3/4" more room Yes I have considered doing that as well, it just keeps getting pushed down the list haha.
