Re: Looking for spark plug recommondations for Victors
[Re: tboomer]
#2796289
07/13/20 08:04 PM
07/13/20 08:04 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
I have used them in, NGK, the past on iron headed and aluminum headed bracket race motors, I've also used Champion, Motorcraft, AC and several other brands that I can't think of now
[Re: mopar dave]
#2796802
07/15/20 03:43 AM
07/15/20 03:43 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I use the NGK 8 heat range in the 500" 12.4:1 Victor MW head engine. . On the mild street 505" 10.3:1 Stealth head engine, The 8's were too cold, so went with 6's. I think the Code is BKR8E (8 = heat range, so change # lower for a hotter plug, or increase # for a colder plug.) if there is a letter after, indicates different tip style, like P for Platinum tip, or I for iridium tip. the last part is a -# (dash number) that is the pre-set spark plug gap in mm/10. example: -10 = 1.0mm or 0.040" gap. The "code" is not the stocking part number. Heck, just found the old thread here: https://board.moparts.org/ubbthread...16/ngk-spark-plug-for-stealth-heads.htmlOld link to chart is broken, found another link with the plug chart here: https://www.lsengineers.co.uk/blog/guide-for-ngk-spark-plug-numbering-system.html
