Paint overspray removal from wire harness #2795894
07/12/20 05:27 PM
07/12/20 05:27 PM
Va
383S_Fastback Offline OP
Va
Looking for recommendations to remove paint overspray from a wire harness. The overspray has been on for at least 30 years so my guess it's enamel, before I start experimenting thought I would ask if anybody knows what works best or if you've tried something and it didn't work or messed up the insulation I would like to hear that too. Hope to remove the overspray and leave the wire markings intact but that's probably not going to happen.
Thanks.
Lee
'67 & '68 Barracuda FB's
'70 AAR Cuda
'89 Ramcharger 4x4
'06 Ram 2500 CTD 6 spd
...Mopars are always way out back
Between the muddy river and the rusty railroad track
Yeah, the Mopars are always hard to find
But you can always find a few
There’s Cordobas and Furys and Darts and Dusters too
There’s a Diplomat with a Swinger
A new Yorker a Demon and a Scamp
And there’s a 68 Barracuda grill with both headlamps...Slaid Cleaves - Skunk Juice
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2795956
07/12/20 08:48 PM
07/12/20 08:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Carb cleaner, acetone, goop off, citrus based hand towels. The towels might stand a better chance of leaving the markings behind. paint stores usually have and overspray remover as well beer
Re: Paint overspray removal from wire harness [Re: TJP] #2796032
07/13/20 01:49 AM
07/13/20 01:49 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Mineral spirits to start. Cured enamel may need some enamel reducer; stronger then spirits but weaker then lacquer/acetone. Is it a wrapped harness, or single wiring.
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2796052
07/13/20 07:26 AM
07/13/20 07:26 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I have been using cheap thinner and a rag to wipe down all my wiring harnesses in the restorations over the years. Yes some of the paint has been on the wires for over 20 years.I clean them a few times until the wires look like new. It removes old oil and grease along with the paints. I use an old tooth brush to scrub the end connectors with the thinner. After cleaning I always check each wire with an ohm meter to see if there are any breaks in the wiring harness. The wires get brittle with age. This method has worked for years of cleaning. Hope this helps.
Re: Paint overspray removal from wire harness [Re: maximus] #2796069
07/13/20 08:58 AM
07/13/20 08:58 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I use lacquer thinner as well. Works quite well. You sometimes loose markings on the wire.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Paint overspray removal from wire harness [Re: 70gtx440dana] #2796269
07/13/20 05:58 PM
07/13/20 05:58 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2796273
07/13/20 06:33 PM
07/13/20 06:33 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Cheap lacquar thinner here for over 40 years, never an issue. ECS sells some wiring part number tags. Keep simple green and any citrus based products away from wiring, especially the terminations, it soaks in and will corrode the wires. Simple green, and that purple power will corrode your terminals. Thinner cleans and evaporates fast, always the best choice.
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2796770
07/14/20 11:54 PM
07/14/20 11:54 PM
Va
Va
Thanks for the reply's and suggestions. Should have mentioned the wire type in 1st post, it's a '70 Cuda trunk harness so it has open wires and some with the cotton braid cover. Tried a couple areas where the wires are exposed along with cleaning the sockets, so far its looking much better. Have only tried acetone and some 3M citrus base cleaner, found that most paint on the wires will scrape off with a finger nail, the sockets not quite so easy. What seemed to work was the citrus base cleaner sprayed on a rag then wipe down the wires, the sockets required a little more effort. I saw the post referring to citrus cleaners causing corrosion after i had already used some, hopefully it wasn't on long enough to start corrosion. Only did a couple small areas to test the outcome. Will go with lacquer thinner next time i have a chance to work on it. The cotton braid may not survive since it's brittle & ready to disintegrate. Here's some before & after pics.
Thanks.
Lee
Edit: I should have mentioned the pic with 3 sockets started out all white prior to cleaning.
Harness before.jpgHarness after pic_1.jpgHarness after pic 2.jpgHarness PN tag.jpg
'70 AAR Cuda
'89 Ramcharger 4x4
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2796799
07/15/20 03:00 AM
07/15/20 03:00 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I haven't tried it on a wiring harness, but brake fluid will remove paint. Used brake fluid to clean overspray off the work bench.
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2797224
07/15/20 10:57 PM
07/15/20 10:57 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Looks good, just use a little light oil on the metal parts and you should be fine. Evans wiring can redo the braid if you need that done.
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2797584
07/16/20 08:31 PM
07/16/20 08:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
If you soaked the sockets and exposed wires for an extended period you might have an issue. Assuming you rinsed them off when done ,and with the galvanizing still being present in your pic's, along with the wires being coated with some form of plastic I seriously doubt you have cause for concern twocents beer
Re: Paint overspray removal from wire harness [Re: 383S_Fastback] #2797586
07/16/20 08:32 PM
07/16/20 08:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
If you soaked the sockets and exposed wires for an extended period you might have an issue. Assuming you rinsed them off when done ,and with the galvanizing still being present in your pic's, along with the wires being coated with some form of plastic I seriously doubt you have cause for concern . Awesome job BTW twocents beer
