Front lug studs.
#2795945
07/12/20 08:19 PM
07/12/20 08:19 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
The issue: Right Stuff Detailing front disc brakes. Studs don't come to the edge of the Centerlines, let alone past the edge of the wheel to be legal at any track. I know there isn't enough engagement on the lugs. The question : what is the rule of thumb for knurl size? The hole is 0.618. I know you want a larger knurl, but how much? Would a 0.625 knurl be large enough or should it be larger to assure they won't spin in the rotor? Thanks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Front lug studs.
[Re: OhioMopar]
#2796006
07/12/20 11:13 PM
07/12/20 11:13 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
The issue: Right Stuff Detailing front disc brakes. Studs don't come to the edge of the Centerlines, let alone past the edge of the wheel to be legal at any track. I know there isn't enough engagement on the lugs. The question : what is the rule of thumb for knurl size? The hole is 0.618. I know you want a larger knurl, but how much? Would a 0.625 knurl be large enough or should it be larger to assure they won't spin in the rotor? Thanks. Call Drdiff he should have what you need I got them from him for my junk
[Re: OhioMopar]
#2796015
07/12/20 11:43 PM
07/12/20 11:43 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
I used Right Stuff for my disc brake conversion and ran Centerline Auto Drags for a while.. I never had a problem passing tech. This was at Quaker City, Norwalk and 42.
Ok
[Re: cudatom]
#2796119
07/13/20 11:27 AM
07/13/20 11:27 AM
Posts: 19,342 north of coder
moparx
i go for around a .010-.015 press fit on a knurled stud. this has worked for me for over 50yrs. when pressing studs, either in or out, support the axle or hub flange well to avoid bending the flange.
[Re: moparx]
#2796140
07/13/20 12:17 PM
07/13/20 12:17 PM
OhioMopar
Mt.Gilead, Ohio
i go for around a .010-.015 press fit on a knurled stud. That's what I was looking for. Thank you.
