4 speed input shaft measurement needed #2795595
07/11/20 07:57 PM
07/11/20 07:57 PM
GA
roadrunninMark Offline OP
GA
Can someone that has a manual transmission laying around do a measurement for me? I need the distance from the face of the transmission to the end of the input shaft. I need the measurement be from a transmission that is compatible in a 69 b body as that is what I have. Thanks
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2795616
07/11/20 09:21 PM
07/11/20 09:21 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
here ya go
Re: 4 speed input shaft measurement needed [Re: PhillyRag] #2795623
07/11/20 09:56 PM
07/11/20 09:56 PM
GA
GA
Thanks Philly, would you call that 8 3/4" or just a little shy of that?
Or is it the sticker says.. 8.66"?
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2795648
07/11/20 11:18 PM
07/11/20 11:18 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Opps: that sticker says 2:66 ratio gears.
Camera shot was fairly straight on: so split the difference.
Re: 4 speed input shaft measurement needed [Re: PhillyRag] #2795754
07/12/20 10:55 AM
07/12/20 10:55 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Input shaft lengths will all be the same. What you need to concern yourself with is the bearing retainer size.
Re: 4 speed input shaft measurement needed [Re: Stanton] #2795778
07/12/20 11:58 AM
07/12/20 11:58 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Also make sure the crankshaft is drilled out for a manual transmission..
Just my $0.02... wink
Re: 4 speed input shaft measurement needed [Re: Sinitro] #2796135
07/13/20 12:05 PM
07/13/20 12:05 PM
GA
GA
Thanks for the additional info on the retainer and crank, I've got that covered. The reason I needed the shaft length measurement is because I have a clutchflite that looked to have the input shaft cut down, which I can now see that it has. I now have to figure out do I need a new shaft, or there some sort of sleeve I can use, or some other solution???
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2796145
07/13/20 12:43 PM
07/13/20 12:43 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That length looks a lot like the amount that's cut off when you don't use a crank that's actually drilled for a factory pilot bushing set up for a 4 speed. twocents
Re: 4 speed input shaft measurement needed [Re: SNK-EYZ] #2796221
07/13/20 04:15 PM
07/13/20 04:15 PM
GA
GA
It is about a 1/2" shorter than the above measurement from Philly.
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2796238
07/13/20 04:59 PM
07/13/20 04:59 PM
A727Tflite Offline
A727Tflite  Offline
Just measured my trans. From the end of the bearing retainer to the start of the wear pattern for the pilot bushing is 2.950”.
From the bearing retainer end to the end of the wear pattern (front) is 3.800”.
Anything longer than that is just going along for the ride.
Hope that helps.
Re: 4 speed input shaft measurement needed [Re: A727Tflite] #2796275
07/13/20 06:44 PM
07/13/20 06:44 PM
GA
GA
Hi Transman,
If I am figuring out your measurements, anything longer than 8.55" from the face of the transmission is "along for the ride". I am only getting about 8.25" on mine, meaning I am still a little short. I was informed that Passon Performance has extended a pilot bearing to make up the necessary distance in 833 four speeds, so I contacted them. I hope to hear back shortly. Sounds like this idea of extending the pilot bearing will work so I won't need another input shaft. at least not for now.
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2796317
07/13/20 09:36 PM
07/13/20 09:36 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
The pilot they're talking about is likely the ball bearing one that fits in the crank register. It would allow for a shorter shaft.
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2796338
07/13/20 10:54 PM
07/13/20 10:54 PM
A727Tflite Offline
A727Tflite  Offline
Hi Transman,
I measured again - maybe this will help.
From the front of the main case to the end of the bearing retainer is 4.275”.
From the end of the bearing retainer to the rear portion of the wear pattern of the pilot bushing is 2.950”.
From the end of the bearing retainer to the forward portion of the wear pattern 3.780”.
I recall that some inputs were cut because the trans was used in a Chevy or Ford application. I don’t recall if they had to be cut for a Mopar application too, or maybe just for an auto trans crankshaft that wasn’t drilled for the bushing. Been too long, sufffer from CRS.
Re: 4 speed input shaft measurement needed [Re: A727Tflite] #2796413
07/14/20 09:22 AM
07/14/20 09:22 AM
GA
GA
Thanks Transman,
Can you do an overall measure, from face of transmission to end of input shaft? Also, can you measure from the beginning of the input shaft to the beginning of the splines?
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2796488
07/14/20 12:13 PM
07/14/20 12:13 PM
A727Tflite Offline
A727Tflite  Offline
Thanks Transman,
I was going to measure from the splines but mine is an 18 spline and it has a much different chamfer.
From the front of the bearing retainer to the end of the input shaft is 4.330” on mine.
Notice the wear pattern.
Re: 4 speed input shaft measurement needed [Re: A727Tflite] #2796586
07/14/20 03:58 PM
07/14/20 03:58 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
My roadrunner 4sp crank was toast...the machine shop found one but it needed to be drilled. Unfortunately they not drill deep enough....trans would not mate up. Rather then disassemble the motor and redrill.... we took about 1/2 off the shaft.
All good
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 4 speed input shaft measurement needed [Re: JMCFAN] #2796641
07/14/20 06:11 PM
07/14/20 06:11 PM
GA
GA
OK, thanks for all the info. I guess it will need to be put together outside the car first and see how much is in the bearing. Maybe I will get lucky and as Transman shows, more than I thought will still be in the bearing.
Re: 4 speed input shaft measurement needed [Re: roadrunninMark] #2797007
07/15/20 02:29 PM
07/15/20 02:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That trans was made for a Chevy engine, why it was cut off. When using the 4 speed trans there was a spacer-adapter to mate the blow shied and trans together but it was still to long so it was shortened. 727 done the same way.
