Tuning tips for running a Dominator on the street #2795430
07/11/20 11:54 AM
07/11/20 11:54 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I have a 1150 Domm with 4 corner idle. Runs fine and no issues, but I know some of you guys have really been able to fine tune them for better street manners. Its on a 12.5-1 493, Indy-1's and indy single plane, 268@.050 solid roller, 5200 converter, 4.10 gears, 295/65 drag radial, guesstimate of 3400lb. Not exacty your average street car but I do ike to cruise on the street from time to time. Any pointers are appreciated!
2 kids and a dog
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795446
07/11/20 12:46 PM
07/11/20 12:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am sure this applies to a dominator as well but this was on a 4150. When I was happy how well my carb ran at wide open I measured all the areas that flowed fuel on the primary side and calculated the fuel flow area. Then knocked down the main jet size until the air fuel ratio cleaned up during street driving and highway cruise. When I was done I calculated the area of flow again, then added the difference back into the power valve channel. This made a carb that cruised clean, got good MPG, and ran the same wide open.
Now, I hated that process, it took awhile with lots of testing and trial and error. I have all these tiny drill bits and pin vices that are no fun to use. That process really made me look into fuel injection and once I switched I couldn't be happier and will never go back.
68 Barracuda Formula S 340
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795450
07/11/20 12:58 PM
07/11/20 12:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Put an O2 gauge on the car so you can see how the adjustments really affect the tune.
Re: Tuning tips for running a Dominator on the street [Re: Bad340fish] #2795462
07/11/20 01:35 PM
07/11/20 01:35 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is the correct way to do it. think of the carb as having three distinct circuits; idle, cruise, power. trying to only use jets for power and cruise usually screws up both circuits. folks ignore the power valve channel restrictions but these passages are the power circuit; jets by themselves aren't.
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795475
07/11/20 01:56 PM
07/11/20 01:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
An AFR gauge and Thumpers cell phone number and a pile of small drill bits...
I tinkered a lot with my 1250, and got ok street manners out of it. But with such a big carb, I found I had to tune it for engine at full temp and hot days. which gave it bad manners on cooler days until the engine was at full temp. Mine was on a 605 Hemi and those are big hemi chambers. I find my little 512 wedge a lot less susceptible to AFR changes my 605 puts the carb thru. So in the end, it was kinda a compromise between the two. A little rich on hot days and a little lean on cool days...And lean as hell during start up. I have now put a 4500 Sniper Stealth on it, and manners have improved...Especially cold starts.
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795508
07/11/20 03:32 PM
07/11/20 03:32 PM
AndyF Offline
AndyF  Offline
Street tuning is going to be difficult due to the cam not the carb. With a big cam like that you'll need a lot of advance at idle. It is difficult to achieve the timing curve you need with a mechanical distributor which is why I'd suggest going digital. If it was my car I'd do a Sniper + Hyperspark combo which will give you complete digital control of fuel and ignition. That setup comes with a wide band and a data logger so you can really dial in the tune. You can do it with a carb and a mechanical distributor but you'll need spend some money to make it work. You might be money ahead to switch to digital.
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795526
07/11/20 04:05 PM
07/11/20 04:05 PM
I would lean down the idle fuel feed and transition fuel feed circuits on the primary side to make it leaner at idle and ight part throttle cruise twocents
I've done that on several two circuits 1050 Dominators for street driving, if you don't know how to identify those circuits and have a pin vise and small # drill bit sets it might be challenging to get it done shruggy work
PM me if you want more information on this up
Dominic, Thumperdart, may be your best choice to do it for you, if he still does customizing customers carbs scope
Re: Tuning tips for running a Dominator on the street [Re: lewtot184] #2795528
07/11/20 04:12 PM
07/11/20 04:12 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks!
2 kids and a dog
Re: Tuning tips for running a Dominator on the street [Re: AndyF] #2795532
07/11/20 04:24 PM
07/11/20 04:24 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Certainly something to consider. My timing is locked out and use a digital 6 w start retard, so I have full advance at idle. Jetting is set where it made the most power on the dyno. Honestly, it runs pretty good and can idle all day, and has great response. Definitely not concerned about gas mileage! Id mostly just like less fumes
2 kids and a dog
Re: Tuning tips for running a Dominator on the street [Re: fast68plymouth] #2795534
07/11/20 04:24 PM
07/11/20 04:24 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I need one!
2 kids and a dog
Re: Tuning tips for running a Dominator on the street [Re: Cab_Burge] #2795535
07/11/20 04:25 PM
07/11/20 04:25 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks Cab!
2 kids and a dog
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795546
07/11/20 04:47 PM
07/11/20 04:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
"Id mostly just like less fumes"
I have a convertible that used to have bad fumes issues, and it was efi'd. The large roller cam kept both valves open long enough so that it would burn your eyes and irritate most anyone that happened to be near the car at idle. It idles very close to 14.5 to 1 AFR too.
I run a warmed up 408 Magnum with a full TTI 3" exhaust with cross over, so I ordered up a pair of high flow, 3 inch inlet/outlet race only cats with a metal matrix and a 4 inch thick main body, welded them on just after my collectors and the car was clean of fumes from then on. They flowed so well, I never felt a power difference, even at full throttle. I was actually pretty surprised at how well they work and that the car didn't slow down.
Re: Tuning tips for running a Dominator on the street [Re: jbc426] #2795608
07/11/20 08:52 PM
07/11/20 08:52 PM
Dragula Offline
Dragula  Offline
On the big Hemi, the fumes are pretty bad anything in AFR of 13.8 or below. I leaned it out to 14.0 and it was noticeably better. Although that's as far as I can go, a wedge, I would bet will have no problem at closer to 14.5 at idle, especially with locked timing. But if you go that far, the warm up becomes more problematic on cooler days...
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795619
07/11/20 09:41 PM
07/11/20 09:41 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Why didn't you tune it while it was on the dyno? I done 2 dom for street driving and it does take a little time. I would get a O2 senor and just take your time.
Joe
Without Data, you’re just another guy with an opinion.
Re: Tuning tips for running a Dominator on the street [Re: sr4440] #2795695
07/12/20 07:11 AM
07/12/20 07:11 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Like said above the fume part may be hard to get rid of. My car will idle as lean as 17:1 out of gear if you want it to and it still stinks, even with 50* of timing. The intake manifold is a real mess at idle when you have a big cam with lots of overlap.
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795715
07/12/20 08:25 AM
07/12/20 08:25 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I need one!
I'm getting ready for a change.....If you want to try one, you have a PM smile
Still 4150 here, but I'll say transfer slot restrictors, followed by IFR were the two most dramatic "normal/gentle street driving"
changes I've made.
On the Dominator you have to figure out what you want to do with the 2 vs 3 circuit deal.
I have never done one but 2 circuit sure seems easier for street....or
at least, alot more like what I'm used to.
Good luck.
Rich H.
Esse Quam Videri
Re: Tuning tips for running a Dominator on the street [Re: ZIPPY] #2795790
07/12/20 12:29 PM
07/12/20 12:29 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
If you want “no fumes” drive a regular daily driver lol
Sounds like you have a radical street car , fumes come with that lol , like rough idle and rubber on the qtr panels
Lmao
....BAD A$$ STREET CAR.....
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2795797
07/12/20 12:44 PM
07/12/20 12:44 PM
The stink comes from unburnt fuel, lean the idle circuits, all four of them, to get rid of the stink scope wrench up
Re: Tuning tips for running a Dominator on the street [Re: Cab_Burge] #2796388
07/14/20 06:12 AM
07/14/20 06:12 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
^^^ THIS grin
Spend the time to dial in the idle/transfer slot circuits then dial in your mains for 2500+ rpm cruise and your PV jets for WOT.
That is the way to do it right, once done right, the difference will be night and day.
Locked out timing really helps to dial it in right, as does an O2 sensor. I ran both 2 and 3 circuit Doms, the 2 circuit was much easier to dial in right.
Even with a 280 @.050"roller and .750" lift.....idles in the high 14s, cruises at light throttle in the low-mid 14s, no surging, 12.5s at WOT.
It can be done, EFI will need the same amount of dialling in to get right, sometimes more. Its just a different way of doing the same thing up
PS: No stink, plugs are awesome.
Re: Tuning tips for running a Dominator on the street [Re: TonyS451] #2796454
07/14/20 11:30 AM
07/14/20 11:30 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
your combo is very close to mine. I use a 1100 dominator on my 511 from Thumpercarbs and it's awesome on the street or track. It has .040 IFR's and .055 T-slots. PM me and i'll give ya the whole combo if your interested. The carb is so dosile with good street manners that you might think it has a 600 holley on it if ya didn't know better. This is a 2 circuit carb. It can set for hours and when i hit the start button, it fires to life and idles nice without touching the throttle. You might even think it was fuel injected.
