Diaphram clutch pedal adjustment #2795403
07/11/20 10:49 AM
07/11/20 10:49 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Hey All,
When using a diaphram clutch in our old mopars what is the best method to adjust free pedal play and the pedal stop?
Thanks,
nd65
Re: Diaphram clutch pedal adjustment [Re: nd65] #2795404
07/11/20 10:58 AM
07/11/20 10:58 AM
N
NITROUSN Offline
NITROUSN  Offline
N
The only adjustment is on the rod underneath. That is a variable to a lot of people. Most important thing is that the throw out bearing in not spinning when disengaged. As far as a stop there is no adjustment the over center spring pops the pedal back against the rubber stop.
Re: Diaphram clutch pedal adjustment [Re: NITROUSN] #2795407
07/11/20 11:05 AM
07/11/20 11:05 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I recall in a Rick Ehrenberg article he said you need to install a pedal stop when switching to a diaphram clutch. He stated you can over extend and damage the clutch.
Re: Diaphram clutch pedal adjustment [Re: NITROUSN] #2795409
07/11/20 11:07 AM
07/11/20 11:07 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The over center spring should be removed when a diaphragm clutch is used.
Re: Diaphram clutch pedal adjustment [Re: NITROUSN] #2795413
07/11/20 11:13 AM
07/11/20 11:13 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I adjust by measuring the clearance between the disc and pressure plate/flywheel. I shoot for .060"" and let free plat at the pedal be what it is, after all what is important is that the disc is disengaged when the pedal is down, not how much slop there is at the pedal with it up.
Remove the clutch inspection cover, have someone floor the clutch pedal, measure the gap between the disc and flywheel, .060" is what I go for. Adjust the rod as needed to get into spec, cycle the clutch pedal a couple of times and recheck, adjust if needed and you are done.
Re: Diaphram clutch pedal adjustment [Re: nd65] #2795416
07/11/20 11:15 AM
07/11/20 11:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
So your want to put a stop to prevent over engagement? You would have to devise some sort of travel limiter. Not sure why as almost all mopars had a diaphragm style clutch.
Re: Diaphram clutch pedal adjustment [Re: nd65] #2795417
07/11/20 11:18 AM
07/11/20 11:18 AM
GomangoCuda Offline
GomangoCuda  Offline
That style of pressure plate does have a shorter stroke so a down stop is a good idea.(actually a good idea for any clutch)
I have seen some pretty nice adjustable stops that people have fabricated. I used a chunk of 2X4 under the carpet for years. whistling
Re: Diaphram clutch pedal adjustment [Re: NITROUSN] #2795420
07/11/20 11:22 AM
07/11/20 11:22 AM
GomangoCuda Offline
GomangoCuda  Offline
Nope runaway
Re: Diaphram clutch pedal adjustment [Re: GomangoCuda] #2795425
07/11/20 11:44 AM
07/11/20 11:44 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Nope runaway
I should correct what I was trying to say. Mopars that run a diaphragm style may or may not need the over spring or stop . Follow the manufacturers instructions.
Re: Diaphram clutch pedal adjustment [Re: nd65] #2795459
07/11/20 01:31 PM
07/11/20 01:31 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Determining the pedal stop's travel limit is done in combination with setting the full clutch release free play. You can adjust it so that your feeler gauge will just fit in between the pressure plate, clutch disc and flywheel when the clutch pedal is all the way on the floor. I used to start with the feeler gauge not being able to fit between the clutch disc etc when pushed all the way to the floor , and then increase the adjustment using the clutch rod until I got the desired release clearance. That way I would have the correct clearance when the pedal is fully depressed when fully on the floor.
In a lot of cases, this will mean that the clutch pedal will not come up enough for the over center spring to lift the pedal past the over center point of the spring's top-of-travel resting position. I used to have to use my toe to bring the clutch pedal the rest of the way up. This is another reason why some people remove the over center spring.
Spend the time to make sure all the connecting points in the linkage are square to each other where they connect. I have always had to straighten out linkage parts when assembling the Z-bar components.
Another trick I learned while trying to set-up my clutch release mechanism is to lubricate all the parts that contact each other with synthetic disc brake grease. It outlasts and outperforms any other lubricant that I have found and won't attack rubber or plastic.
As my old autoshop teacher used to say, the only time clutch parts wear when set-up correctly is when they are being used, so keep your foot off the pedal, hand off the shifter(to reduce wear on the shift forks and synchros) and use the clutch's "slip" as minimally as possible to reduce wear and keep the heat down in it.
I cringe when I see how much some people unnecessarily over slip and ride the clutch when they drive a manual transmission car, and learn how to heal-toe the brake and gas pedal to start moving on a hill start if you don't know how to do it yet..
Re: Diaphram clutch pedal adjustment [Re: Sniper] #2795470
07/11/20 01:50 PM
07/11/20 01:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Problem with that is, if there is a lot of pedal free play you get into the over center spring which will pull the pedal down. Above works OK if the OC spring is removed.
Re: Diaphram clutch pedal adjustment [Re: John_Kunkel] #2795500
07/11/20 03:04 PM
07/11/20 03:04 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I appreciate the comments. The over center is removed and an adjustable pedal stop in place.
nd65
Re: Diaphram clutch pedal adjustment [Re: John_Kunkel] #2795501
07/11/20 03:11 PM
07/11/20 03:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The standard recommendation when running a diaphragm clutch is to remove the over center spring regardless.
Re: Diaphram clutch pedal adjustment [Re: Sniper] #2795510
07/11/20 03:34 PM
07/11/20 03:34 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
FYI, when designing my hydraulic clutch linkage, I contacted Centerforce tech line about the Dual Friction 10.5" disc & diaphragm pressure plate.
This was their reply: "The disc will be released with an 0.030” air gap. Linear travel at the bearing is 3/8” to release. Bearing load is 500 lbs."
May be useful to someone shruggy
Re: Diaphram clutch pedal adjustment [Re: DrCharles] #2795622
07/11/20 09:50 PM
07/11/20 09:50 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Same .030 here. That was the recommended back in the 60's and 70's by Schieffer and Zoom on their diaphragm clutches. Much more than that would cause the pedal to stick to the floor on shifts above 6000 rpm.
Re: Diaphram clutch pedal adjustment [Re: nd65] #2795742
07/12/20 10:05 AM
07/12/20 10:05 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My CF has been in for years Its been beat on and still works like new,Center spring removed and just the spring for the fork.I adjust all my clutchs so that they just engane Reverse easily.Ive had to adjust y Cf once in years.Only like 1 turn or so on the rod.With a scatter shield its just about impossible to get to the disc to check clerance.Rocky
Chrysler Firepower
Re: Diaphram clutch pedal adjustment [Re: GomangoCuda] #2795810
07/12/20 01:31 PM
07/12/20 01:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sure like to hear the reasoning for this
Re: Diaphram clutch pedal adjustment [Re: cudaman1969] #2795814
07/12/20 01:34 PM
07/12/20 01:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Go read John Kunkel's post
Re: Diaphram clutch pedal adjustment [Re: cudaman1969] #2795865
07/12/20 04:12 PM
07/12/20 04:12 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Because the over-center spring helps to bring pedal down not up. It's only needed with a 3 finger design to help your leg push down that race-style design. Generally when left in place with a diaphragm style your pedal will stay to the floor with high RPM's.
Ron
Re: Diaphram clutch pedal adjustment [Re: RJS] #2795889
07/12/20 05:02 PM
07/12/20 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Actually it does both; at the top of the pedal travel it pulls the pedal up, after traveling over center it pulls the pedal down and reduces the leg effort.
