magnum force lower control arm crack #2794017
07/07/20 06:31 PM
07/07/20 06:31 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
My Bud has the original k frame it his challenger race car .Lucky the control arm break was after he put the car back in the trailer. As it turns out Magnum force did an upgrade due this issue with street cars breaking them more often. Magnum Force will not remake these even in a thicker wall size. We checked with S & W they may make a set but not sure. Any body know of a set hanging on a wall or one of the talented moparts guys who is familiar with this and can make a set. ?? Thanks
Re: magnum force lower control arm crack [Re: dart9ss] #2794025
07/07/20 06:44 PM
07/07/20 06:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Can you post a picture....I will check mine....
Re: magnum force lower control arm crack [Re: Dragula] #2794067
07/07/20 08:51 PM
07/07/20 08:51 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Photos
Re: magnum force lower control arm crack [Re: dart9ss] #2794104
07/07/20 10:33 PM
07/07/20 10:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Any hints where the crack was found in the pics?
Re: magnum force lower control arm crack [Re: jcc] #2794110
07/07/20 10:48 PM
07/07/20 10:48 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Guessing this is it
Re: magnum force lower control arm crack [Re: MoonshineMattK] #2794123
07/07/20 11:07 PM
07/07/20 11:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, that would be my guess, but anybody who would drive it that way with that "fix" is really taking a chance. That looks like a poor repair, of a bad design.
Re: magnum force lower control arm crack [Re: jcc] #2794254
07/08/20 10:49 AM
07/08/20 10:49 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Hey Its not about a repair to reuse the broken arm . Its if someone has a pair they would like to sell. or can recommend someone to make a set.. The car was sitting on the header . It was welded back together to roll the car out of the trailer. Thanks
Re: magnum force lower control arm crack [Re: dart9ss] #2794277
07/08/20 11:40 AM
07/08/20 11:40 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
And, decent local race car shop , chassis builder should be able to build a nice set of them ..or, ship one to me and we can get it made here easily
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: magnum force lower control arm crack [Re: bigdad] #2794355
07/08/20 01:58 PM
07/08/20 01:58 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Thanks Big Dad, were waiting to see if S & W can reproduce them with a thicker tube and bracing. Ill pm you later on if we strike out. Thanks
Re: magnum force lower control arm crack [Re: dart9ss] #2794406
07/08/20 04:16 PM
07/08/20 04:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A thicker tube solution is only a band aid for normally a poor design. The failure issue will not be removed unless the thickness is dramatically increased. I would suggest figure out from a few knowledgeable sources what is causing the fracture, what solutions are likely to fix it, and then decide the one best for you. Copying it often seldom gives a customer a better solution, more likely the same or worse. This is a non redundant catastrophic failure part. You don't have the luxury of OEMs of doing a lot of FEA/destructive testing, etc. You need to get it right, you(?) were lucky the first time, eventually the odds will catch up with you.
Re: magnum force lower control arm crack [Re: jcc] #2794477
07/08/20 07:27 PM
07/08/20 07:27 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
16 years of wheel stands I would say it held up pretty good. no reason why it cant be replaced,and improved the car drives straight and solid at 147 mph has for all those years.
Re: magnum force lower control arm crack [Re: dart9ss] #2794593
07/09/20 06:15 AM
07/09/20 06:15 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So then maybe go a thinner tube and save some weight and go faster?
Re: magnum force lower control arm crack [Re: jcc] #2795038
07/10/20 08:17 AM
07/10/20 08:17 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
liberal Arts Major , wise guys go far in this world and a liberal schmuck as well. Keep your wise cracks off my post!!
Re: magnum force lower control arm crack [Re: dart9ss] #2795043
07/10/20 08:40 AM
07/10/20 08:40 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
That Challenger has always been nice and fast! I hope you can find a solution to the problem. Years ago a friend purchased a Magnum Force front end for his Dart and encountered problems during installation but eventually got it to work. He sold the front end to my mentor/ trans builder/friend for his sons Dart and its working well now. I didn't get to see you at Mopars at the Patch , I didn't have my Dart there and my friend was racing my pickup due to a knee injury on my part
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: magnum force lower control arm crack [Re: jcc] #2795057
07/10/20 09:07 AM
07/10/20 09:07 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
haha
Re: magnum force lower control arm crack [Re: dart9ss] #2795145
07/10/20 01:25 PM
07/10/20 01:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Feeling a little threatened? tsk
Re: magnum force lower control arm crack [Re: dart9ss] #2795194
07/10/20 03:06 PM
07/10/20 03:06 PM
moparx Online content
moparx  Online Content
i can see that tube has no gussets on either side.
could you add them easily, and would they interfere with anything in the suspension travel ?
beer
Re: magnum force lower control arm crack [Re: moparx] #2795315
07/10/20 10:14 PM
07/10/20 10:14 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
threatened ? I would send you a P M but your over the limit on private messages!! I guess your caustic personality has others wondering what kind of an AA-HOLE you must be. down Yes there are no gussets , brackets for travel limiters . Car drivers like its on rails. We Made the mopar day, the track was like Ice from all the street cars. Not much prep for the pro class. I did see your truck there, but not you. hope all is well.
Re: magnum force lower control arm crack [Re: dart9ss] #2795354
07/11/20 06:47 AM
07/11/20 06:47 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well, I got my answer. up
Re: magnum force lower control arm crack [Re: jcc] #2795361
07/11/20 07:48 AM
07/11/20 07:48 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Yes u DID!!
just as suspected. haha.
once again I proved my point!
you are too easy haha
