Re: Extra Fluid in Oil Pan
[Re: Wailin D]
#2800448
07/23/20 11:32 PM
07/23/20 11:32 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I had one 413 industrial HD truck block that had freeze cracks on the external driver side of the block and one in #3 cylinder, I had it sleeved and try to fix the external crack myself The sleeved leak and so did my fix On the positive side I've had a lot of Mopar blocks sleeve successfully with no issues One of my customers had a 1965 426 street wedge block that had two external freeze cracks and one internal casting flaw that leak coolant into the oil pan, I had all three fixed by drilling and pinning after he insisted on fixing that block, that was a long time ago and it was $100.00 a inch back then at a decent machine shop, I think his bill was over $600.00 to fix the three cracks in that block
