Transmission fluid for a Rossler Race turbo 400 #2794733
07/09/20 02:04 PM
07/09/20 02:04 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
What are you using in your race Turbo 400 transmissions?
I heard type F works great in them.
Any input?
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Sammy] #2794739
07/09/20 02:15 PM
07/09/20 02:15 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have used type F
....BAD A$$ STREET CAR.....
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Sammy] #2794744
07/09/20 02:25 PM
07/09/20 02:25 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Any input?
I got a not that said 50/50 Dexron/type F
Re: Transmission fluid for a Rossler Race turbo 400 [Re: n20mstr] #2794767
07/09/20 03:09 PM
07/09/20 03:09 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by n20mstr
I have used type F
And what about now?
Did you switch
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Sammy] #2794814
07/09/20 04:26 PM
07/09/20 04:26 PM
N
n20mstr Offline
n20mstr  Offline
N
I have used type F
And what about now?
Did you switch
Well, I have experimented. A buddy gave me a 5gal bucket of AW32 hydraulic oil which is 20w, which is the same? as type F anyway?
Whatever the case, I have mixed it 50/50 with type F as it was free...LOL
My converter stalls at 2900 on the brake (NO chip) and it slips 8% at the finish line.
Follow Rosslers recommendation, best thing you can do.
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Clanton] #2794818
07/09/20 04:30 PM
07/09/20 04:30 PM
NC
440Jim Offline
440Jim  Offline
NC
After reading that, and knowing how expensive that transmission is;
I would just run one of the recommended racing transmission fluids (B&M or TCI).
It's not like your going to change the fluid every race day...
Re: Transmission fluid for a Rossler Race turbo 400 [Re: n20mstr] #2795027
07/10/20 06:53 AM
07/10/20 06:53 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I have used type F
And what about now?
Did you switch
iagree I have an ATI TH400 and they recommend Type F so that's what I use. No issues with mine.
Re: Transmission fluid for a Rossler Race turbo 400 [Re: blowndart] #2795041
07/10/20 08:32 AM
07/10/20 08:32 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I run 400's in 2 cars. I run redline racing synthetic type F. No friction modifiers added.
I have also used John Deer Hy-gard. Thicker than type F.
I have no idea if any fluid is actually better than any other. I do know first hand that viscosity changes behavior.
Re: Transmission fluid for a Rossler Race turbo 400 [Re: dthemi] #2795152
07/10/20 01:41 PM
07/10/20 01:41 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Seems the turbo 400 takes less fluid than a torqueflite. Both have 8 inch converters. Am I wrong?
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Sammy] #2796499
07/14/20 12:52 PM
07/14/20 12:52 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
ISO 68 synthetic compressor oil.
Re: Transmission fluid for a Rossler Race turbo 400 [Re: BobR] #2799013
07/20/20 04:24 PM
07/20/20 04:24 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I use type F but I hear a lot of people using John Deere HyGuard
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Transmission fluid for a Rossler Race turbo 400 [Re: Sammy] #2799131
07/20/20 08:50 PM
07/20/20 08:50 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I picked up some TCI Max Shift today at Summit but I am not sure of the brand of Ftype I will get if any.
