Front end alignment? #2794408
07/08/20 04:27 PM
07/08/20 04:27 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I'm going to take my street/strip Dart to get the front end aligned. What specs would you guys recommend?
Thanks.
Re: Front end alignment? [Re: justinp61] #2794428
07/08/20 05:33 PM
07/08/20 05:33 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
this is my preferred , I do my own .
Camber = 0 to - 1/4 neg
Caster = some positive but never had the want for massive amount ( + 3 or more ) , currently has + 1/2 to + 3/4 .
Toe = 1/16
Caster often is a compromise especially if lowered and stock arms / upper bushes
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Front end alignment? [Re: tex013] #2794454
07/08/20 06:33 PM
07/08/20 06:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In my race car I have
Caster at -- 8*
Camber at 0
Toe in at 0"
this is a strut front end
On my street rod
Caster at 6*
Camber at 0
Toe in 1/32"
strut front end also
With stock A-arms you wont get much caster.. maybe max of 3* (I doubt)
wave
Re: Front end alignment? [Re: MR_P_BODY] #2794505
07/08/20 08:56 PM
07/08/20 08:56 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Remember to set alignment at the ride height going down the track at.
Re: Front end alignment? [Re: Sammy] #2794530
07/08/20 10:48 PM
07/08/20 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We normally set that at 1" above curb ride height
wave
Re: Front end alignment? [Re: MR_P_BODY] #2794549
07/09/20 02:05 AM
07/09/20 02:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If its a stock front end as my 63 is I give it all the pos caster I can which will be maybe close to 2 at the most. Camber at 0 and toe in about 1\16. Ron
Re: Front end alignment? [Re: 383man] #2794644
07/09/20 10:10 AM
07/09/20 10:10 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Moog makes some offset upper control arm bushings which are the cheapest way to gain a little more positive caster. Just install them one back one forward.
https://www.amazon.com/Moog-K7104-Control-Offset-Bushing/dp/B000C55Z8K
Re: Front end alignment? [Re: Sammy] #2794703
07/09/20 01:08 PM
07/09/20 01:08 PM
W. Kentucky
W. Kentucky
Even on a street/strip car?
Thanks guys.
Re: Front end alignment? [Re: justinp61] #2794710
07/09/20 01:17 PM
07/09/20 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks guys.
It helps some but not mandatory
wave
Re: Front end alignment? [Re: justinp61] #2794859
07/09/20 05:32 PM
07/09/20 05:32 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Thanks guys.
I don't worry for street strip . And yes you can fit offset bushes if desired for extra caster . I have no issues @ 130mph , which makes me kinda slow . But quickish for a street car daily driver .
Tex
New best MPH 130.32
Re: Front end alignment? [Re: tex013] #2795166
07/10/20 02:17 PM
07/10/20 02:17 PM
moparx Offline
moparx  Offline
tex, at one time, were offset poly upper bushings made there ?
are they still available if so ? TIA !
beer
Re: Front end alignment? [Re: justinp61] #2795223
07/10/20 05:07 PM
07/10/20 05:07 PM
I set my Caster, camber and toe in at one inch above at rest heights up
Re: Front end alignment? [Re: Cab_Burge] #2795275
07/10/20 08:08 PM
07/10/20 08:08 PM
W. Kentucky
W. Kentucky
Even on your street/strip cars Cab?
Re: Front end alignment? [Re: justinp61] #2795297
07/10/20 09:10 PM
07/10/20 09:10 PM
Absolutely up
I don' do much low speed light part throttle cruising shruggy devil
Re: Front end alignment? [Re: moparx] #2795343
07/11/20 02:15 AM
07/11/20 02:15 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
beer
Not sure , only ever needed to use offset bushes once on a a body with rack conversion .
I will ask about
Tex
New best MPH 130.32
Re: Front end alignment? [Re: tex013] #2795440
07/11/20 12:38 PM
07/11/20 12:38 PM
moparx Offline
moparx  Offline
beer
I will ask about
Tex
up thanks !
beer
