ABS light after braking over rough pavement 05 T&C van #2793007
07/05/20 03:45 PM
07/05/20 03:45 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
Just after light braking steeply downhill over some very rough and rutted blacktop pavement,
the yellow ABS light lit.
Brake fluid reservoir full.
Brakes still work good & smoothly in full panic stop from 55 mph.
2005 3.3 Chrysler Town and Country extended van 111,000 miles
Is this a common problem?
Will the ABS go out on its own after some period if no further fault occurs?
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793133
07/05/20 08:36 PM
07/05/20 08:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Many of the parts stores have scan tools that can pull ABS codes. Have them pull the code and see if you can get them to clear it. It may clear and that be the end of it. Otherwise, you have the code to direct you to the problem area.
Master, again and still
Re: ABS light after braking over rough pavement 05 T&C van [Re: DaveRS23] #2793170
07/05/20 10:24 PM
07/05/20 10:24 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
[b][/b]
my 05 ram did the same thing ,the wire connector/plug at the rear diff had become corroded inside,had to pull wire,clean and put dielectric grease onmaybe check any wire connections....[u][/u]
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793174
07/05/20 10:36 PM
07/05/20 10:36 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Did it stay on ?
if not it sounds like its doing its job.
Re: ABS light after braking over rough pavement 05 T&C van [Re: gtx6970] #2793187
07/05/20 11:38 PM
07/05/20 11:38 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
On my caravans, it was usually the wheel sensor. Recently had to change the front driver side sensor on my 2005 Grand Caravan as it was intermittent. Found that the gear wheel has rusted and expanded causing the sensor to rub and fail. My buddy found it with his scanner. But I did have the ABS brain go bad in the 2005 years ago. Again my buddy's scanner found the problem. $50 junk yard replacement fixed it.
Re: ABS light after braking over rough pavement 05 T&C van [Re: DaveRS23] #2793242
07/06/20 07:07 AM
07/06/20 07:07 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Does a particular name brand parts store
officially use a name brand manufacturers Scan Tool advanced enough
that its software can read Mopar ABS codes?
I did the ignition key on-off-on-off-on and the digital odometer read
P0441 - done
which is the famous
“loose gas cap or Natural Vacuum Leak Detector (NVLD system”
Diagnostic Trouble Code
I then plugged in a OBD-II Superchips Tuner for a Ram pickup that can also read and reset DTC’s and it also displayed the one P0441 only.
Re: ABS light after braking over rough pavement 05 T&C van [Re: markz528] #2793246
07/06/20 07:16 AM
07/06/20 07:16 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Thank you for the reply.
I will attempt to eyeball the front driver side sensor and wheel.
I read on another forum that there is a
frame rail mounted front-driver-side wire bundle that contains an ABS wire pair
near the wheel that can suffer from wheel debris and water spray.
A T&C van owner said he bought a
“Mopar Wire Pigtail Repair Kit”
to repair his corroded connection.
Re: ABS light after braking over rough pavement 05 T&C van [Re: gtx6970] #2793248
07/06/20 07:23 AM
07/06/20 07:23 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Originally Posted by gtx6970
Did it stay on ?
The yellow ABS light has steadily stayed on,
never going off even for a short time,
despite an OBD-II DTC “reset codes” command,
and removing the negative battery cable for one hour.
When the battery cable was reconnected and the van restarted
the yellow ABS light was on even before the van was put in gear and moved.
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793250
07/06/20 07:28 AM
07/06/20 07:28 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Does a particular Android app for OBD-II scanning have advanced enough capabilities to read Mopar ABS codes?
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793255
07/06/20 07:53 AM
07/06/20 07:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The ABS system doesn't talk through the OBD stuff as far as I know. I know when I had a problem with my 97 Jeep Cherokee I tried to have a friend at a firestone scan it and they said only a dealer could do that.
You might remove the battery cables for a few minutes and try again?
68 Barracuda Formula S 340
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793276
07/06/20 09:15 AM
07/06/20 09:15 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Our local O'reilly's scan tool is ABS capable. Common ABS codes can usually be pulled with a scan tool that can do ABS. ABS is separate from OBD because they are 2 different computers in the car. But ABS doesn't usually take a trip to the dealer to diagnose. Just ask at any of your local parts stores. Not a big deal IF the counter monkey has any idea how to use scan tool.
Re: ABS light after braking over rough pavement 05 T&C van [Re: DaveRS23] #2793346
07/06/20 11:46 AM
07/06/20 11:46 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Yellow ABS light just went out
after I had driven 100 yards or so towards my local O’Reillys Auto Parts
to attempt to get an ABS error scan.
A new corollary to Murphy’s Law!
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2793371
07/06/20 12:09 PM
07/06/20 12:09 PM
moparx Offline
moparx  Offline
my opinion ? look for loose, corroded connections.
or possibly your van's name is cristine ? biggrin
beer
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2794426
07/08/20 05:25 PM
07/08/20 05:25 PM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Have now travelled over 150 miles and the ABS light has stayed off.
Re: ABS light after braking over rough pavement 05 T&C van [Re: 360view] #2794460
07/08/20 06:53 PM
07/08/20 06:53 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That's what mine would do and it was the wheel sensors. Sometimes the gap gets too wide also. I expect it to come back on.
Re: ABS light after braking over rough pavement 05 T&C van [Re: markz528] #2794723
07/09/20 01:50 PM
07/09/20 01:50 PM
moparx Offline
moparx  Offline
are the tone wheels rusty ?
i have seen rust flakes come off of them and stick to the magnets on the sensors.
after cleaning the sensors of particles, and wire brushing the tone wheels of loose stuff, all is well afterward.
just something you could look for.
glad it seems fixed for now. up
beer
