Re: Front end alignment?
[Re: justinp61]
#2794428
07/08/20 05:33 PM
07/08/20 05:33 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
this is my preferred , I do my own . Camber = 0 to - 1/4 neg Caster = some positive but never had the want for massive amount ( + 3 or more ) , currently has + 1/2 to + 3/4 . Toe = 1/16 Caster often is a compromise especially if lowered and stock arms / upper bushes
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2794454
07/08/20 06:33 PM
07/08/20 06:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
In my race car I have Caster at -- 8* Camber at 0 Toe in at 0" this is a strut front end On my street rod Caster at 6* Camber at 0 Toe in 1/32" strut front end also With stock A-arms you wont get much caster.. maybe max of 3* (I doubt)
[Re: Sammy]
#2794703
07/09/20 01:08 PM
07/09/20 01:08 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
Remember to set alignment at the ride height going down the track at. Even on a street/strip car? Thanks guys.
[Re: justinp61]
#2794710
07/09/20 01:17 PM
07/09/20 01:17 PM
MR_P_BODY
Remember to set alignment at the ride height going down the track at. Even on a street/strip car? Thanks guys. It helps some but not mandatory
[Re: justinp61]
#2794859
07/09/20 05:32 PM
07/09/20 05:32 PM
tex013
Sydney,Australia
Remember to set alignment at the ride height going down the track at. Even on a street/strip car? Thanks guys. I don't worry for street strip . And yes you can fit offset bushes if desired for extra caster . I have no issues @ 130mph , which makes me kinda slow . But quickish for a street car daily driver . Tex
[Re: moparx]
#2795343
07/11/20 02:15 AM
07/11/20 02:15 AM
tex013
Sydney,Australia
tex, at one time, were offset poly upper bushings made there ? are they still available if so ? TIA ! Not sure , only ever needed to use offset bushes once on a a body with rack conversion . I will ask about Tex
[Re: tex013]
#2795440
07/11/20 12:38 PM
07/11/20 12:38 PM
Posts: 19,239 north of coder
moparx
tex, at one time, were offset poly upper bushings made there ? are they still available if so ? TIA ! Not sure , only ever needed to use offset bushes once on a a body with rack conversion . I will ask about Tex thanks !
