New Garage floor NON-SLIP Epoxy ? ? ?
#2793869
07/07/20 11:48 AM
07/07/20 11:48 AM
Posts: 3,810 New State
kidmopar
New State
Hello All ! Hope everyone is doing well ! Any recommendations on putting a NON - SLIP Epoxy on brand new garage floor ? ? ? Brand new house that gets 95 degree heat & 20 degree snow on occasion ...... ( Neighbor had "something" put down & he's VERY disappointed as it's a 'Banana Peel' when wet ! ) Any services that do this ? I'm 65 and not sure I could do a project like this Any & all help very warmly appreciated ! Kevin
Re: New Garage floor NON-SLIP Epoxy ? ? ?
[Re: kidmopar]
#2793904
07/07/20 01:47 PM
07/07/20 01:47 PM
Posts: 631 Casco, MI
Savoy1964
Casco, MI
When its installed you can get a silica sand type product that makes it very non slip along with the paint chips. They also recommend sanding and acid etch of the concrete, sealing and then paint.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Savoy1964]
#2794056
07/07/20 08:16 PM
07/07/20 08:16 PM
Posts: 2,056 NW/Indiana - Chi town
ricomondo
I live in Indiana and had a company come out from about 2 hrs away. Epoxy with the colored flakes and a bit of aluminum silica for grip. It can still be a bit slippery, but on my last garage I had them use a lot of silica and the mop head left all kinds of fuzz from the grip. There's a happy medium I'm sure. And as mentioned above, they will still have to diamond grind the concrete for proper adhesion, new pour or not.
GY3 71 Demon 340
[Re: kidmopar]
#2794134
07/08/20 01:08 AM
07/08/20 01:08 AM
Posts: 22,695 Bitopia
jcc
Bitopia
I use a solvent based two part quality epoxy (Palguard) for color, toughness, and adhesion. I don't believe an etch or sand blast or grind is necessary for all the garage floors I have done. More important they be dry, and as oil free as you achieve. Oil that soaks into raw concrete, is not mechanically removed, period. After the above epoxy cures, I top coat the epoxy with clear two part solvent based urethane, which looks and wears great, doesn't dull/chalk, and makes clean ups a cinch, when wet, its slippery, and I'm OK with that. I believe any additives applied for extra grit, are just a never ending future source of "dust", as the gritted surface abraids, the whole point I paint raw concrete in the first place. So pick your poison.
[Re: kidmopar]
#2794378
07/08/20 03:02 PM
07/08/20 03:02 PM
Posts: 701 Northern California
lilcuda
Northern California
Keep in mind that while the abrasive silica they give you to put down is good for traction when the floor is wet, it makes the floor a total pain to clean. That stuff tears up anything you try to use to mop up messes. I did my own U CoatIt epoxy on the floor on the garage at my previous house it that stuff was hard to get spread around evenly and was no fun to try to clean.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: lilcuda]
#2794380
07/08/20 03:09 PM
07/08/20 03:09 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I just coated part of my garage floor w a new Rustoleum product, I did NOT use the included paint chips to prevent slipping for exactly that reason my floor is a working floor and making it easier to keep clean was the purpose of the coating. My advice in applying it, is apply it thicker than you think, I sporead mine too thin and got a lot of pin spots as a result.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
