Re: Your opinions on this launch Gents
[Re: rb446]
#2794357
07/08/20 02:01 PM
07/08/20 02:01 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My car....... 68 B body.......would slow down pretty noticeably from a stiff head wind.
I’m sure after a few tweaks and with some better weather it’ll show some improvement.
[Re: Cab_Burge]
#2794360
07/08/20 02:11 PM
07/08/20 02:11 PM
Posts: 570 UK
rb446
UK
Its got 90/10's but they could be shot?..and I'll have to check for binding on arms as well as the back that the spring bolts have not been over-tightened. I was going to go with a baseline of upper hole in bars and an airgap (no preload) with shocks on max stiff to start but that didn't go down to well with my mate. We will get there,...as I said prior I worked it out that the car had 10.20's in it tops, (hp/weight) were not too far from that now with a lot of things to change and better weather, and no exhausts and I'm relying on the dyno to be somewhere near accurate for the hp no's.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2794365
07/08/20 02:35 PM
07/08/20 02:35 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Tighten the rear shock (Ext) Try launching from a lower rpm (the tyre was wadding when he loaded it before he launched @ 1.10 ish) Check front travel (5" min) More rear tyre pressure or a stiff sidewall or a radial slick. Lower the rear end and keep it in the lower Caltrac hole.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2794384
07/08/20 03:18 PM
07/08/20 03:18 PM
Posts: 570 UK
rb446
UK
Tighten the rear shock (Ext) Try launching from a lower rpm (the tyre was wadding when he loaded it before he launched @ 1.10 ish) Check front travel (5" min) More rear tyre pressure or a stiff sidewall or a radial slick. Lower the rear end and keep it in the lower Caltrac hole. Yes Tig I didn't like how it loaded the rear either, those 90/10's are history, already spoke to John about that. If his tyre guage (old metal type!!) was correct we already had 16psi in them, we would be getting into radial pressures soon with a Bias tyre?, we gotta make the best with what we got, but he will change shocks and I don't think we want to hit the tyre any harder without a shock that will handle the rebound which we don't have now. I asked him about lowering the car, its no no at the moment. And yes it looks like its topping those shocks and unloading the tyres to a degree. Lots to correct but encouraging day none the less.
[Re: MR_P_BODY]
#2794385
07/08/20 03:20 PM
07/08/20 03:20 PM
Posts: 570 UK
rb446
UK
You might need more shock travel on the fronts... see if you have about 5" of travel.. you might need more pitch rotation I agree, I'd like the rear to move just enough to plant the tyres and pull the fronts some and carry them nice and smooth, but it don't have to be to the 60. Parts like front shocks etc. have been on there for years when the car was raced in the states, always been a race car from day 1.
[Re: rb446]
#2794554
07/09/20 02:25 AM
07/09/20 02:25 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It works pretty good right now. Our cars are close but your a little faster then mine. We weigh close to the same as my 63 goes about 3725 without my 185 so I am just over 3900 total. My best id 10.76 @ 124.99. I have run over 125 mph but it spun and the et was in the 10.80's which I usually run. My best 60 is a 1.50 but its usually between 1.50 and 1.53. I don't use Cal Tracs or adjustable shocks though as I just use SS springs and the longer MP shocks. But your running pretty good right now. Ron
[Re: 383man]
#2794590
07/09/20 05:54 AM
07/09/20 05:54 AM
Posts: 570 UK
rb446
UK
Hi Ron, yes we had some issues with spin Sunday but we'll get on top of things next time out with some new front shocks and work. Cars are very similar in that my mate is more street than strip really although he don't go far with it, just to shows and about 4>5 trips to the track, runs in our version of NSS brkts so we gotta get it consistent. Even with the way it was on the day we did 1.51>1.50>1.50 60's which isn't bad but it picked up a 1/10th every time which is just not good enough for competition, don't know if he's shifting the same every time, just gotta get him a bit more focused for competition and we should do good when the cars sorted better.........cheers.
