Where is the headlight relay, 1979 Dodge W150 truck? #2793860
07/07/20 11:23 AM
07/07/20 11:23 AM
God's Country Maryland
GODSCOUNTRY340 Offline OP
Can't find it, where is it hidden?
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: GODSCOUNTRY340] #2793862
07/07/20 11:27 AM
07/07/20 11:27 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't believe they had one.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: stumpy] #2793872
07/07/20 11:59 AM
07/07/20 11:59 AM
Is there a circuit breaker somewhere? There's no fuse for the headlights in the fusebox. Can't get any juice to the headlights or dimmer switch on the floor. Parking lights and turn signals work. I'm getting ready to pull the headlight switch after lunch.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: GODSCOUNTRY340] #2793886
07/07/20 12:36 PM
07/07/20 12:36 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
built into the Headlight switch
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: CSK] #2794032
07/07/20 07:17 PM
07/07/20 07:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
iagree
You could go with a HL relay kit that Crackedback sells.
Abe Lincoln
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: dart4forte] #2794039
07/07/20 07:34 PM
07/07/20 07:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
No relay I recall. Had all 4 h4's go out on my 79 warlock II years ago and a new headlight switch straightened it out. Of course, I tried not running the high beams too long at nights after that, but damn they lit up the boony roads well.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: buildanother] #2794064
07/07/20 08:36 PM
07/07/20 08:36 PM
Well, pulled the switch, used a jumper wire on the harness and got all 4 headlights working. Checked the switch and there's no continuity between the power and headlight terminal. Thanx for all the input.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: GODSCOUNTRY340] #2794068
07/07/20 08:55 PM
07/07/20 08:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Headlights are on a non fused separate power feed. Tail lights have a fused feed from the fuse panel. There should be a black wire at the switch 10 or 12 gauge and that should have power from the fuse link. I think the yellow goes to the dimmer switch. Check for power at the black. If no power you need to trace the wires. Suspect area is the bulkhead.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: NITROUSN] #2794076
07/07/20 09:10 PM
07/07/20 09:10 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Adding relays is a great idea, it takes a lot of load off the switch.
Modern switches are not anywhere near the quality the original switches were. I put 4 different aftermarket switches on my son's car before we got one that actually worked. Each switch had a different issue. All 4 switches were from local auto parts stores (each store only had one on the shelf), but once out of the box, all 4 looked identical.
Be forewarned, just because you have installed a new headlight switch, that no longer means you have installed a good switch. Gene
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: poorboy] #2794569
07/09/20 02:50 AM
07/09/20 02:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Adding a relay is a great idea. Back in the 90's we had trouble with Dodge trucks burning the contacts on the headlite switches and headlties going out. It was because of the high current the headlites carry that over time it burned the switch. So they came out with a TSB to install a relay for the headlites to take the load off the switch. I installed many back then as they even had a part # for the harness with the relay they gave us to wire in. Ron
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: 383man] #2794630
07/09/20 09:32 AM
07/09/20 09:32 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
Ron that was on the 94 and newer trucks. I agree we also updated a lot of them. Still a good idea on the older trucks.
Re: Where is the headlight relay, 1979 Dodge W150 truck? [Re: NITROUSN] #2794990
07/10/20 12:12 AM
07/10/20 12:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted by NITROUSN
Quote
Your right as I forgot what year it started. Sometimes we got trucks in for it that already had it done so I would save the relay and harness and over the years I saved about 4 of them. Ron
