Bolt size - e-body - sway bar to k-frame #2792050
07/02/20 09:29 PM
07/02/20 09:29 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
My car had a k-frame replaced years ago..It had 7/16x1.5 bolts holding the brackets to the k-frame. It had 5/16 bolts holding the sway bar clamps to the bracket. I swapped the k-frame for an Al Debevic converted hemi k-frame. The sway bar bracket holes have flash and won't take a bolt currently w/o opening up (PS steering box was very difficult to fit also, and motor mount has to be cut for oil pump clearance w/motor mount, so not an easy swap). Trying to determine if 7/16 or 3/8 is actual size to use before I open holes.
*** So can somebody please tell me the bolt size for the mount-to-k-frame pieces? ***
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792365
07/03/20 03:51 PM
07/03/20 03:51 PM
moparx Offline
moparx  Offline
the first question i would ask is, what size hole is in your bar mounting brackets.
i'm not trying to be a smartazz. this simple question will determine the size needed in the K.
beer
Re: Bolt size - e-body - sway bar to k-frame [Re: moparx] #2792403
07/03/20 06:24 PM
07/03/20 06:24 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
No Prob. 7/16 is what the bracket is. I'm just curious as I have 2 K-frames, one with holes, and one with weld-splash choking the holes. And the one that the sway bar was on had been replaced, likely when the car lived in the UK.
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792409
07/03/20 06:58 PM
07/03/20 06:58 PM
AndyF Offline
AndyF  Offline
If this is a restoration question then post it in the resto forum and somebody will tell you the size of the bolt as well as the correct head marking and coating. If this is just a driver then it doesn't matter. Use what fits. Factory bolts were probably 3/8-16. The FSM might tell you and show torque specs.
Re: Bolt size - e-body - sway bar to k-frame [Re: AndyF] #2792448
07/03/20 08:58 PM
07/03/20 08:58 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
https://www.ebay.com/itm/Fits-Mopar-64-69-Sway-Bar-Support-Mount-Bolts-SuperBee-RoadRunner-Dart-Charger/293523810207?hash=item445761e79f:g:j5UAAOSwJiReespP
These are the original style bolts I can't get to my car right now, if this doesn't help maybe tomorrow I can get to it.
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792611
07/04/20 12:33 PM
07/04/20 12:33 PM
moparx Offline
moparx  Offline
if the brackets have 7/16" holes, then more than likely, it uses 3/8" bolts. just standard engineering practice to ensure assembly is possible with tolerance stack ups.
i would use 3/8" bolts, grade 5 at least, of the correct length needed.
beer
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792625
07/04/20 12:59 PM
07/04/20 12:59 PM
New Jersey Bada Bing
bremotorsports Offline
Go to my website, and separately punch these numbers into the green search button:
1718
1719
Both types were used for your application.
Bill Rolik
www.billrolikenterprises.com
Re: Bolt size - e-body - sway bar to k-frame [Re: hemirdrnnr] #2792701
07/04/20 04:41 PM
07/04/20 04:41 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Are these the brackets you are talking about, if so the bolts are 5/16 - 18 thread and thread is 1"
Re: Bolt size - e-body - sway bar to k-frame [Re: hemirdrnnr] #2792710
07/04/20 05:15 PM
07/04/20 05:15 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thanks for the pict and info. I was unclear in my description. I have an 71 E-body. Mine look totally different. Those are self-locking nuts. 7/16 and 5/16. The straps may be homemade for all I can tell. 7/8 bar. I have two 1.125 bars, but they wont fit with the skidplate.
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792758
07/04/20 08:21 PM
07/04/20 08:21 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Sorry I should have ask , now I need to find a new good deed before dark Good Luck! runaway
Re: Bolt size - e-body - sway bar to k-frame [Re: hemirdrnnr] #2792776
07/04/20 08:57 PM
07/04/20 08:57 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
You did a good deed! It counts!
Re: Bolt size - e-body - sway bar to k-frame [Re: Vert] #2792902
07/05/20 10:47 AM
07/05/20 10:47 AM
moparx Offline
moparx  Offline
i am not familiar with an E-body, but i have seen that type of mounting setup before.
if you want to use what you have, and the brackets fit your hole spacing, just drill your K holes to the size needed for the bolts you have.
just my opinion, nothing more.
if factory correctness is your goal, a FSM is necessary, and the restoration forum can help you find the answer.
beer
