Wheel bearing dust caps #2791699
07/01/20 10:41 PM
07/01/20 10:41 PM
Falcon, CO
71pettyblue Offline OP
Falcon, CO
Putting a '67 Coronet RT together for a friend, anyone have a source for new dust caps? I don't need NOS, reproductions are good enough.
Thanks,
Tony
Retired Mopar Enthusiast
Re: Wheel bearing dust caps [Re: 71pettyblue] #2791860
07/02/20 10:29 AM
07/02/20 10:29 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
NAPA or whomever sells Dorman ones maybe.
Re: Wheel bearing dust caps [Re: Neil] #2791875
07/02/20 11:06 AM
07/02/20 11:06 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
https://forum.e-bodies.org/wheels-t...s-cheap-tool-for-dentless-install/16945/
These dust caps were discussed recently on E-bodies.org. There are part #s in the link but double check that your friends 67 takes the same ones. The new caps have a tall lip. Taller then original ones. You might have clearance issues with the wheel center cap if you don't trim the caps to sit more flush to the hubs.
Re: Wheel bearing dust caps [Re: 71pettyblue] #2791892
07/02/20 11:45 AM
07/02/20 11:45 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Thanks,
Joe Suchy did at one time have some.
joesuchy@64gmail.com
Re: Wheel bearing dust caps [Re: pushbutton] #2791894
07/02/20 11:48 AM
07/02/20 11:48 AM
New Jersey Bada Bing
bremotorsports Offline
I always have them in stock!
Bill Rolik
bremotorsports@verizon.net
201-394-5533 Cellular
www.billrolikenterprises.com
Hit the green search button and type 1613416-P !!!
Re: Wheel bearing dust caps [Re: burdar] #2791896
07/02/20 11:49 AM
07/02/20 11:49 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
When I was restoring my T/A I really wanted to find new dust caps, and the ones I found and purchased didn’t fit!
I finally gave up and reused my dinged up old ones.
The new ones all had made in China stamped in them. Which we’d carefully polished off before installing, I should have waited until I’d tried them to see if they’d fit before wasting the time polishing.
Re: Wheel bearing dust caps [Re: 71pettyblue] #2791928
07/02/20 01:41 PM
07/02/20 01:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For drum brakes NAPA NOE 7302437
Re: Wheel bearing dust caps [Re: John_Kunkel] #2791953
07/02/20 04:10 PM
07/02/20 04:10 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
Dorman 13996; ordered from Rock Auto, Dr. Diff
Re: Wheel bearing dust caps [Re: fal3] #2792150
07/03/20 12:19 AM
07/03/20 12:19 AM
Falcon, CO
Falcon, CO
Guys, thanks for the responses. I'm also working on my friend's 56 Fury, the caps are also beat up and they fit the RT. That size must have been used by Mopar for many years.
Tony
Re: Wheel bearing dust caps [Re: 71pettyblue] #2792151
07/03/20 12:40 AM
07/03/20 12:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Last i ckd they were still avail thru Mopar.
been a few years since Ive ckd though.
Re: Wheel bearing dust caps [Re: gtx6970] #2792158
07/03/20 01:05 AM
07/03/20 01:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The cap bore size of aftermarket rotors is inconsistent.
Dorman # 13996 caps fit the OEM Mopar bore spec.
Dorman # 618-101 caps fit the smaller bore variants.
