73-74 b body torque shaft/z-bar mounting #2790536
06/28/20 11:08 PM
06/28/20 11:08 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Can anyone furnish a picture or any info on the frame side bracket for the clutch torque shaft on a 73-74 b-body? I am in a conversion and bought the bracket that is advertised for 71-74 B and E bodies. The bracket fit the frame perfectly but it mounts the torque shaft to high horizontally. The factory part numbers for 71-74 E-Bodies and 71-72 B-Bodies are the same. 73-74 b-bodies have a different part number so there has to be a differance. Makes sense due to 73-74 b-bodies went to the isomount k-frame and the frame rails are obviously different. Just trying to find a picture or info of the differance. Any help would be appreciated and Thank You!
Re: 73-74 b body torque shaft/z-bar mounting [Re: 340cpe] #2791701
07/01/20 10:46 PM
07/01/20 10:46 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Well I figured it might be a long shot, due to the 73-4’s not being to popular. I did locate a picture and the slot for the ball stud is square at the bottom instead of being rounded. It’s not clear if it is cut deeper toward the frame as compared to the 71-2 e and b body bracket. Was looking for any first hand info prior to making any modifications. Would still welcome any info and Thank You!
